Home » Language IDEs » C / C++ IDE (CDT) » Error Parser
Error Parser [message #99690] Wed, 14 April 2004 01:00 Go to next message
Daniel Jeller is currently offline Daniel JellerFriend
I'm not able to get the Error Parser Working!
I've read all the instructions form the eclipse help, but nothing seems
to work!
All I get is the Error Output in the Console-, but not in the Problems -
View.
I'm using the M8 Version and MinGW 3.1.0.
I have all the error parsers in the properties window enabled, and have
tried everything i could imagine.
I hope someone can help me.
Daniel
Re: Error Parser [message #99742 is a reply to message #99690] Thu, 15 April 2004 00:08 Go to previous messageGo to next message
> to work!
> View.
Copy/paste here or in a CDT bugzilla PR(the output of the build)
from the console.
That would help us see why no patterns were found.
I would prefer a bugzilla PR, to track this down, (I know ..
this is longer and more cumbersome 8-). But it helps track
problems and beside you could flip it to "critical" before the release
that should get our attention 8-).
> Daniel
Re: Error Parser [message #99825 is a reply to message #99742] Thu, 15 April 2004 10:06 Go to previous messageGo to next message
>>to work!
>>View.
> from the console.
>>Daniel
ok, i'll do that!
Thank you
Re: Error Parser [message #100215 is a reply to message #99825] Mon, 19 April 2004 16:35 Go to previous messageGo to next message
Renato Garcia is currently offline Renato GarciaFriend
try filters in the problems view and select C problems.
Renato
> >>to work!
> >>View.
> > from the console.
> >>Daniel
> ok, i'll do that!
> Thank you
Re: Error Parser [message #100280 is a reply to message #100215] Mon, 19 April 2004 22:15 Go to previous message
> Renato
>>>>to work!
>>>>View.
>>>from the console.
>>>>Daniel
>>ok, i'll do that!
>>Thank you
Thanks, but that doesn't seem to work!!
I have tried all kind of settings within filters and run/debug and c++
settings in the preferences menu.
i don't know if i made a mistake or have encountered a bug..
I guess i'll just wait for M9 or the 2.0 final..
Previous Topic:M8, Build with <ctrl>-B
Next Topic:Managed Make Extensions
Current Time: Thu Jan 02 17:17:05 GMT 2025
Powered by FUDForum. Page generated in 0.04367 seconds
