Home » Language IDEs » Java Development Tools (JDT) » finding the implementing interfaces of an IType
finding the implementing interfaces of an IType [message #99132] Fri, 26 September 2003 08:14 Go to next message
Suppose I have an instance of IType. I want to get the list of immediate
interfaces it implements. I found there are two options -
1. use IType#getSuperInterfaceNames() and then IType#resolveType()
2. use IType#newSupertypeHierarchy() and then
ITypeHierarchy#getSuperInterfaces
I found that these methods are too slow for me, because I invoke them on
almost all files in a java project.
Can anybody provide an insight on how to do perform this operation most
efficiently?
Genady
Re: finding the implementing interfaces of an IType [message #99213 is a reply to message #99132] Fri, 26 September 2003 09:42 Go to previous message
You could build the type hierarchy once on the Java project using
IJavaProject.newTypeHierarchy(IRegion, IProgressMonitor) passing in a region
that contains the whole project. This will resolve the super types of all
types in the region only once.
Jerome
"Genady" <eclipse@genady.org> wrote in message
news:bl1ah2$fef$1@eclipse.org...
> efficiently?
> Genady
Previous Topic:Ctrl+O extremally slow in I20030925
Next Topic:Source not found for RemoteTestRunner.run() line: 277
Current Time: Wed Oct 22 16:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.03466 seconds
