| ASMModelWrapper => getModelFactory().getResourceSet() != getModelLoader().getResourceSet() [message #98719] | Thu, 29 January 2009 22:02  |  |
| Eclipse User  |  |  |  |  | Looking at the ATL 3.0 code, I noticed that there are two ways to get different ResourceSet objects:
 org.eclipse.m2m.atl.core.emf.EMFModelFactory.getResourceSet( )
 org.eclipse.m2m.atl.drivers.emf4atl.EMFModelLoader.getResour ceSet()
 Suppose we have:
 ASMModelWrapper modelWrapper = ...
 we can do:
 ResourceSet rSet1 = modelWrapper.getModelFactory().getResourceSet();
 ResourceSet rSet2 = modelWrapper.getModelLoader().getResourceSet();
 and we have:
 Assert.isTrue(!(rSet1.equals(rSet2));
 I also noticed that
 org.eclipse.qvt.declarative.relations.atlvm.utils.ASMEMFMode lUtils is
 using the old ATL APIs.
 Whoever fixes this will have to decide one way or the other how to get a
 ResourceSet. This might seem like a design detail to some but it is an
 important choice. Consistent use of ResourceSet objects is one of the
 weakest aspects of the M2M architecture in my opinion. I don't know what
 to suggest. Hopefully some smart people have thought about this already...
 -- Nicolas.
| [ATL] Re: ASMModelWrapper => getModelFactory().getResourceSet() != getModelLoader().getResourceSe [message #98735 is a reply to message #98719] | Fri, 30 January 2009 04:13   |  |
| Eclipse User  |  |  |  |  | Hello,
 Those methods corresponds to two different strategies, you don't have to
 use them simultaneously.
 ATL launch configs, ant tasks, or any java-based app need to use the
 core api to launch ATL. Then this api manages models depending of the
 ATLVM you want to use: using EMFModelFactory (EMFVM) OR EMFModelLoader
 (RegularVM).
 So the ResourceSet use is delegated to a sub-layer, which clients are
 not supposed to deal with.
 Why this kind of architecture?
 At least, we intent to switch definitely to only one ATLVM (EMFVM). But
 as there are still missing features on the EMFVM (e.g. Debugger) and
 some other projects strongly depending on RegularVM (TCS), we were
 forced to do a transitional wrapper for RegularVM, using the
 EMFModelLoader mechanism.
 The ATL core api abstract layer allowed us to create a wrapper for the
 RegularVM, which ever had a kind of API (which had a lot of conception
 problems).
 > Suppose we have:
 > we can do:
 > and we have:
 As I explained before, you are not supposed to do that.
 > I also noticed that
 At this time qvt declarative is still in a incubation phase, so it will
 keep using ATL2.0 api, for the moment.
 > important choice.
 Consider that the old API is deprecated. But in fact, the intermediate
 layer between clients and VMs allows to switch from a strategy to another.
 > -- Nicolas.
 We ever did a lot of work about that, especially with Dennis Wagelaar's
 help. He did some successfull tries on ATL model handlers API (old one),
 then we applied those principles on the new one.
 In a few words, ATL creates an unique resourceSet for each
 transformation, which is "garbage collected" after execution. As EMF
 automatically load resources, it avoids a memory overflow which was
 occuring after a lot of launches.
 I will try to give more explanations, schemas, on the wiki about all of
 that ASAP :-).
 William
| Re: [ATL] Re: ASMModelWrapper => getModelFactory().getResourceSet() != getModelLoader().getResour [message #98781 is a reply to message #98735] | Fri, 30 January 2009 11:49  |  |
| Eclipse User  |  |  |  |  | William Piers wrote: > Hello,
 > (RegularVM).
 If we chain launch configurations, then what you are saying suggests
 that we need to use the same ATLVM for all launch configurations in that
 chain.
 Ah, thanks for the clarification.
 >> Consistent use of ResourceSet objects is one of the weakest aspects of
 >> the M2M architecture in my opinion. I don't know what to suggest.
 >> -- Nicolas.
 > that ASAP :-).
 Thanks.
 -- Nicolas.
 > Best regards,
 > William
FUDForum. Page generated in 0.04208 seconds
