| [Teneo] LazyInitializationException [message #97955] |
Fri, 28 September 2007 07:33  |
I am trying to handle LazyInitializationException in teneo 0.8.
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg03083.html
I am trying according to steps mentioned in above post (which were for
0.7.5) but didn't work.
I think I may not be doing it right for 0.8.
If I override & synchronize delegateSize() method in my class (which
extends HibernatePersistableEList)
protected synchronized int delegateSize()
return super.delegateSize();
I
then it works but makes the loading very very slow.
If I don't override this method and just do above steps then I still get
error:
org.hibernate.LazyInitializationException: illegal access to loading
collection
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
org.hibernate.collection.AbstractPersistentCollection.readSi ze(AbstractPersistentCollection.java:109)
at org.hibernate.collection.PersistentList.size(PersistentList. java:91)
org.eclipse.emf.common.util.DelegatingEList.delegateSize(Del egatingEList.java:231)
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:434)
org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:222)
org.eclipse.emf.common.util.DelegatingEList$EIterator.hasNex t(DelegatingEList.java:1048)
Any suggestions?
Thanks.
| Re: [Teneo] LazyInitializationException [message #98028 is a reply to message #98000] |
Sun, 30 September 2007 01:09  |
Hi Parvez,
Looking at the old post you refer to. The lazyinitializationexception occurs because you have
multi-threaded access to one list (correct?).
If this is the case then this exception (in this case) can only be prevented by synchronizing the
access to the list (at least when it is initializing).
After the list has been initialized then the size method should be very quick. So I do not
understand why synchronizing this method makes the system very slow. Can you check what takes so
much time there (is the cpu 100%, are there multiple threads waiting for this method, is the size
method called many times?)?
gr. Martin
PC wrote:
> Hi Martin,
> Here it is:
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> com.pilz.pas.platform.iface.model.impl.DepthFirstVisitorImpl .visitDeviceInterface(DepthFirstVisitorImpl.java:81)
> at
> com.pilz.pas.platform.iface.model.impl.DeviceInterfaceImpl.a pply(DeviceInterfaceImpl.java:282)
> at
> com.pilz.pas.platform.iface.model.impl.DepthFirstVisitorImpl .visitRoot(DepthFirstVisitorImpl.java:246)
> at
> com.pilz.pas.platform.iface.model.impl.RootImpl.apply(RootIm pl.java:178)
> at
> com.pilz.pas.platform.runtime.logic.internal.BuildManager.st artBuild(BuildManager.java:96)
> at
> com.pilz.pas.platform.gui.internal.jobs.DownloadBinariesJob. run(DownloadBinariesJob.java:85)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Thanks.
> - Parvez
> Martin Taal wrote:
>> Can you post the complete stacktrace?
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> for 0.7.5) but didn't work.
>>> @Override
>>> I
>>> get error:
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Any suggestions?
>>> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] LazyInitializationException [message #609850 is a reply to message #97955] |
Fri, 28 September 2007 11:07  |
gr. Martin
PC wrote:
> @Override
> I
> error:
> collection
> at
> at
> at
> at
> at
> at
> at
> Any suggestions?
> Thanks.
The Netherlands
| Re: [Teneo] LazyInitializationException [message #609851 is a reply to message #97985] |
Fri, 28 September 2007 11:13  |
Hi Martin,
Here it is:
collection
at com.pilz.pas.platform.iface.model.impl.RootImpl.apply(RootIm pl.java:178)
Thanks.
- Parvez
Martin Taal wrote:
> gr. Martin
> PC wrote:
>> @Override
>> I
>> get error:
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any suggestions?
>> Thanks.
| Re: [Teneo] LazyInitializationException [message #609853 is a reply to message #98000] |
Hi Parvez,
gr. Martin
PC wrote:
> Hi Martin,
> Here it is:
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks.
> - Parvez
> Martin Taal wrote:
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> @Override
>>> I
>>> get error:
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Any suggestions?
>>> Thanks.
The Netherlands
FUDForum. Page generated in 0.08615 seconds
