Swing RCP [message #97713] |
Thu, 08 December 2005 20:51 |
Originally posted by: m.n.com
Has anyone tried to use or come up with a solution to view Birt Reports
from a Swing RCP? The app will be webstarted so the file/report needs
to be streamed down from the server. Or something like that. I've
searched for PDF viewers and they are very expensive or outdated.
Re: Swing RCP [message #98488 is a reply to message #97713] |
Mon, 12 December 2005 14:39 |
Well, I've been doing some digging. I've seen JRex in the past and
though I would give it a whirl. I think it will work. The only issue I
have is showing a PDF stream. I have a work around, but I would rather
use a stream than a URI. Or at least have the choice.
So either I can use JRex to display the report via servlet, or via a pdf
stream via a service.
FUDForum. Page generated in 0.04487 seconds
