Home » Archived » Test and Performance Tools Platform (TPTP) » Installing new Agent
Installing new Agent [message #97245] Fri, 27 April 2007 19:38 Go to next message
Originally posted by: nick.mortimer.csiro.au
Hi All, I'm foxed by problems with profiling a Java 6 application. I have
installed all the newtec client and agent. I run the agent and fire off my
application and nothing happens. The application does not appear.
Here is my check list.
If I try to profile with out stating the ACServer.exe then I get error
connection failed
If ACServer.exe running first time nothing happens then second time
FATAL ERROR: JVMPI, an experimental interface, is no longer supported.
Please use the supported interface: the JVM Tool Interface (JVM TI).
For information on temporary workarounds contact: jvmpi_eol@sun.com
Error occurred during initialization of VM
-Xrun library failed to init: piAgent
Could not resolve to JVMPI interface
I know others have had this problem and I have read as much as I can but
still can't seem to get it sorted any help would be greatfullly recieved!
Cheers
Nick
Re: Installing new Agent [message #97260 is a reply to message #97245] Sat, 28 April 2007 09:25 Go to previous message
> have installed all the newtec client and agent. I run the agent and fire
> off my application and nothing happens. The application does not appear.
> connection failed
> Cheers
> Nick
Things are getting better, no JVMPI error now it was my instalation that
was the problem, but now the application just doesn't apear and no data
is collected.
Nick
Previous Topic:error IWAT0435E an error occured when connecting to the host
Next Topic:Agent Controller exception on CentOS 4.1
Current Time: Fri Apr 18 10:40:59 EDT 2025
Powered by FUDForum. Page generated in 0.10438 seconds
