Home » Archived » DSDP - Mobile Tools for Java (MTJ) » New Use Case documents added to Wiki
New Use Case documents added to Wiki [message #8774] Mon, 28 November 2005 11:00 Go to next message
Minna Bloigu is currently offline Minna BloiguFriend
Member
To begin the week with interesting discussions, there are new use cases
added to Wiki for commenting:
- Build the project (priority 1, modified from an earlier post in this
newsgroup)
http://eclipsewiki.editme.com/MTJ-build-project
- Edit source code (priority 1)
http://eclipsewiki.editme.com/MTJ-edit-source-code
- Create a new class (priority 2, updated to wiki from an earlier post in
this newsgroup
http://eclipsewiki.editme.com/MTJ-create-class
- Sign the application (priority 2)
http://eclipsewiki.editme.com/MTJ-sign-application
These use cases do not currently have a responsible owner, so we will update
them according to discussions before an owner is agreed. If you would like
to provide more input to these use cases or become an owner, please inform
us. All comments are welcomed.
Rgds,
Minna
Re: New Use Case documents added to Wiki [message #8810 is a reply to message #8774] Mon, 28 November 2005 18:33 Go to previous messageGo to next message
> newsgroup)
> this newsgroup
> Rgds,
> Minna
Hi Minna,
Thanks for the additions to the Wiki.
I am interested in working on the "Edit source code" part.
Can you please list everything that a "use case owner" is expected to do?
I may not have enough "free time" to be a use case owner.
:Steven in Dallas
Re: New Use Case documents added to Wiki [message #8817 is a reply to message #8810] Tue, 29 November 2005 06:45 Go to previous messageGo to next message
Member
Good to hear from you Steve,
and it is nice to notice that there is interest to these subjects.
We have added a proposal of the requirements process and the use cases to
wiki. You can take a look at http://eclipsewiki.editme.com/MTJ-process and
comment the proposal as well if you like.
In the process proposal we suggest that after a use case is approved to be
in a scope of MTJ, the owner of the use case is responsible of describing
the use case in a more detailed level. The use case can be reviewed again
after the use case is sufficiently outlined and the feature functionality
described. If the use case is approved to be specified enough, the described
feature can be implemented based on the use case contents.
The owner of the use case in the implementation phase does not have to be
the same as the one defining the use case contents and feature
functionality. The proposed MTJ requirements process diagram in the wiki
describes the different steps and phases for a use case perhaps little
better.
Rgds,
Minna
> Hi Minna,
> :Steven in Dallas
Re: New Use Case documents added to Wiki [message #8824 is a reply to message #8817] Thu, 01 December 2005 17:13 Go to previous messageGo to next message
> better.
> Rgds,
> Minna
>>Hi Minna,
>>:Steven in Dallas
Hi Minna,
Thanks for the clarifications and the link to updates.
I'll check everything out and get back to you in this "chain" of posts.
:Steven
Re: New Use Case documents added to Wiki [message #10861 is a reply to message #8817] Fri, 02 December 2005 21:11 Go to previous messageGo to next message
> better.
> Rgds,
> Minna
>>Hi Minna,
>>:Steven in Dallas
Moi Minna,
I can be the "owner" of the "Edit source code" part.
I will think about things related to the use case you've put together so
far and make some additional proposals next week.
:Steven in Dallas
Manage runtime updated [message #10888 is a reply to message #8774] Thu, 08 December 2005 13:09 Go to previous messageGo to next message
Member
Hi all,
a new version of the manage runtime use case is now added to Wiki for
community review. The name of the use case is changed to Manage SDK in order
to reflect more the idea of the contents in the document.
The Manage SDK use case is on its own page and editable, but the limitations
with the characters that the eclipse Wiki allows might require that we have
to split
it to several pages. If you can't edit the page, you can send your comments
to this newsgroup or via email.
Manage runtime documents are located in:
MTJ > MTJ Use Cases > Manage runtime
http://eclipsewiki.editme.com/MTJ-manage-runtime
or you can access directly the latest addition Manage SDK in:
MTJ > MTJ Use Cases > Manage runtime > Manage SDK
http://eclipsewiki.editme.com/MTJ-manage-SDK
Rgds,
Minna
Re: Manage runtime updated [message #10915 is a reply to message #10888] Mon, 12 December 2005 07:06 Go to previous messageGo to next message
Member
Following the proposed MTJ Use Case process, the Manage SDK Use Case is now
in Community Review until 18.12.05. During this time you can give your
comments and change requests to the use case. We hope to get the PMC
approval to start the implementation of this Use Case in the beginning of
next week.
Rgds,
Minna
Re: Manage runtime updated [message #11001 is a reply to message #10915] Mon, 19 December 2005 13:29 Go to previous messageGo to next message
Member
Hi all,
the community review for the Manage SDK use case has now ended. The use case
is currently waiting for the PMC approval to get implemented.
Rgds,
Minna
Deploy the application in community review [message #11013 is a reply to message #8774] Tue, 20 December 2005 10:56 Go to previous message
Member
The Deploy application Use Case is now added to wiki for community review.
The Use Case is in community review until 5th of January due the holidays.
The main page for the use case is located in:
MTJ > MTJ Use Cases > Deploy the application
http://eclipsewiki.editme.com/MTJ-deploy-application
The deploy application functionality is divided into following three
documents:
http://eclipsewiki.editme.com/MTJ-deploy-application-main
Deploy the application to device
http://eclipsewiki.editme.com/MTJ-deploy-device
Deploy the application to FTP server
http://eclipsewiki.editme.com/MTJ-deploy-ftp
Rgds,
Minna
Re: New Use Case documents added to Wiki [message #562915 is a reply to message #8774] Mon, 28 November 2005 18:33 Go to previous message
> newsgroup)
> this newsgroup
> Rgds,
> Minna
Hi Minna,
:Steven in Dallas
Re: New Use Case documents added to Wiki [message #562942 is a reply to message #8810] Tue, 29 November 2005 06:45 Go to previous message
Member
better.
Rgds,
Minna
> Hi Minna,
> :Steven in Dallas
Re: New Use Case documents added to Wiki [message #563019 is a reply to message #8817] Thu, 01 December 2005 17:13 Go to previous message
> better.
> Rgds,
> Minna
>>Hi Minna,
>>:Steven in Dallas
Hi Minna,
:Steven
Re: New Use Case documents added to Wiki [message #563099 is a reply to message #8817] Fri, 02 December 2005 21:11 Go to previous message
> better.
> Rgds,
> Minna
>>Hi Minna,
>>:Steven in Dallas
Moi Minna,
:Steven in Dallas
Manage runtime updated [message #563149 is a reply to message #8774] Thu, 08 December 2005 13:09 Go to previous message
Member
Hi all,
to split
Rgds,
Minna
Re: Manage runtime updated [message #563206 is a reply to message #10888] Mon, 12 December 2005 07:06 Go to previous message
Member
next week.
Rgds,
Minna
Re: Manage runtime updated [message #563376 is a reply to message #10915] Mon, 19 December 2005 13:29 Go to previous message
Member
Hi all,
Rgds,
Minna
Deploy the application in community review [message #563393 is a reply to message #8774] Tue, 20 December 2005 10:56 Go to previous message
Member
documents:
Rgds,
Minna
Previous Topic:EclipseCon - votes needed
Next Topic:Face to face meeting minutes available in Wiki pages
Current Time: Thu Dec 26 15:20:20 GMT 2024
Powered by FUDForum. Page generated in 0.05114 seconds
