Home » Archived » Visual Editor (VE) » Migrating Visual classes from Websphere to Eclipse
Migrating Visual classes from Websphere to Eclipse [message #96824] Fri, 08 July 2005 04:00 Go to next message
Originally posted by: stephen.okane.syntec-software.de
I've been working with WSAD (most recently 5.1) for the past couple of
years, but have decided to try out eclipse 3.1. I've installed the latest
version of the VE, and tried out a couple of the examples, and everything
seems fine, much better to work with than with WSAD 5.1.
The problem i've encountered is when I open a (visual) class that has been
developed in WSAD 5.1 (and therefore i assume with VE 0.5.0, as i didn't
update it), all i get is a NullPointerException:null
Has anyone else encountered this, can anyone give me advice on how i might
get on the road to solving this problem
Thanks in advance
Sok
Re: Migrating Visual classes from Websphere to Eclipse [message #97008 is a reply to message #96824] Fri, 08 July 2005 09:29 Go to previous messageGo to next message
Stephan,
>I've installed the latest version of the VE
What version of VE is this? 1.1M2? or the latest integration build I20050630?
There are problems running VE 1.1M2 with Eclipse 3.1 GM. Please use I20050630.
What versions of EMF and GEF are you using?
Please attach your .log file so I can look at your stack trace information.
Also... if possible and it's non-confidential, attach the .java file so I can
debug the problem.
Thanks...
Peter Walker
VE Development
Stephen O'Kane wrote:
> Thanks in advance
> Sok
Re: Migrating Visual classes from Websphere to Eclipse [message #97146 is a reply to message #97008] Mon, 11 July 2005 06:40 Go to previous messageGo to next message
Hi Peter,
I was using 1.1M2, but now i've got the newest build (I20050710) installed,
along with GEF3.1 and EMF2.1. The error i now get is as follows;
IWAV0168E Improper nesting of mark statements in Expression. Tried to pop or
endMark to before current mark. Tried to go past Mark# 0
but there are also still NullPointerExceptions in the .log file. I've
pasted the relevant part of the .log file below between the first and second
set of double lines.
After that i decided to remove all the parts of the code that were dependant
on other classes developed by us or change back to their JDK superclass (as
we've extended many classes such as JLabel etc.), so the code is only
(hopefully) using standard java classes, and therefore you should have no
problems with unknown classes if you want to debug it (source attached).
When i ran it, it got a bit further, but still ended up giving me a
NullPointer exception. I've also pasted the relevant part of the .log file
below in between the second and third set of double lines.
Thanks for your help
Stephen
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-11 11:59:42.242
!MESSAGE Exception thrown.
!STACK 0
Wrapped exception
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:536)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:520)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1007)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:1777)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:581)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:646)
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.endDocument(SAXWra pper.java:59)
at org.apache.crimson.parser.Parser2.parseInternal(Unknown Source)
at org.apache.crimson.parser.Parser2.parse(Unknown Source)
at org.apache.crimson.parser.XMLReaderImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:140)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:169)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1093)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:871)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:574)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1985)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Wrapped by
org.eclipse.emf.common.util.WrappedException
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.258
!MESSAGE
+++ Warning +++: Mon Jul 11 11:59:45 CEST 2005 Bad Object: int:
accountNumber
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.273
!MESSAGE
accountNumber{1}
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.289
!MESSAGE
+++ Warning +++: Mon Jul 11 11:59:45 CEST 2005 Bad Object: boolean:
=OP-Bearbeitung/src< com.bmw.nasa.gui.verwaltung.oplist{OpListConfirmationDetails Panel.java[OpListConfirmationDetailsPanel~checkBookingDetail s^correct
!MESSAGE
=OP-Bearbeitung/src< com.bmw.nasa.gui.verwaltung.oplist{OpListConfirmationDetails Panel.java[OpListConfirmationDetailsPanel~checkBookingDetail s^correct{1}
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.305
!MESSAGE
=OP-Bearbeitung/src< com.bmw.nasa.gui.verwaltung.oplist{OpListConfirmationDetails Panel.java[OpListConfirmationDetailsPanel~fireApplied~QApply Event;^currentSize
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.695
!MESSAGE
+++ Warning +++: Mon Jul 11 11:59:45 CEST 2005 Skipping expression:
gegenCdCodeCombobox.setModel(new CDComboBoxModel())
!STACK 0
org.eclipse.jem.internal.beaninfo.core.Utilities.getDecorato r(Utilities.java:198)
org.eclipse.jem.internal.beaninfo.core.Utilities.getProperty Decorator(Utilities.java:225)
org.eclipse.ve.internal.java.codegen.java.PropertyFeatureMap per.hardCode(PropertyFeatureMapper.java:108)
org.eclipse.ve.internal.jfc.codegen.AttributeFeatureMapper.p rocessHardCodedProperty(AttributeFeatureMapper.java:97)
org.eclipse.ve.internal.java.codegen.java.PropertyFeatureMap per.getFeature(PropertyFeatureMapper.java:140)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.Initialize(AbstractExpressionDecoder.java:100)
org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.decode(AbstractExpressionDecoder.java:139)
org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .decodeExpression(CodeExpressionRef.java:292)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeExpression(JavaSourceTranslator.java:585)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:708)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:835)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:908)
!ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 11:59:45.820
!MESSAGE
message = "Beleg (" + accountNumber + ") ist schon vorhanden f
Re: Migrating Visual classes from Websphere to Eclipse [message #97160 is a reply to message #97146] Mon, 11 July 2005 07:00 Go to previous message
Hi again,
I've found out what the problem could be, and am not sure if it is a
mis-understanding from me or a bug (probably the first). I've followed the
instruction for downloading Eclipse 3.1, JRE1.4.2 is installed as my system
default, and have got the latest integration build of VE, plus GEF 3.1 and
EMF 2.1.0
What seems to be the problem is that the project i'm developing is still be
be run under JRE1.3.1, so the project setting where setup for that. when i
switched to the default (i.e. 1.4.2) then there was no problems.
So the question is; Even though Eclipse is running under 1.4.2, can i not
use the VE to develop a project under an earlier version of java?
Stephen
"Stephen O'Kane" <stephen.okane@syntec-software.de> schrieb im Newsbeitrag
news:datier$h77$1@news.eclipse.org...
> Hi Peter,
> installed, along with GEF3.1 and EMF2.1. The error i now get is as
> follows;
> or endMark to before current mark. Tried to go past Mark# 0
> second set of double lines.
> dependant on other classes developed by us or change back to their JDK
> superclass (as we've extended many classes such as JLabel etc.), so the
> code is only (hopefully) using standard java classes, and therefore you
> should have no problems with unknown classes if you want to debug it
> (source attached). When i ran it, it got a bit further, but still ended up
> giving me a NullPointer exception. I've also pasted the relevant part of
> the .log file below in between the second and third set of double lines.
> Stephen
// Log file info deleted
> !ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 12:26:03.617
> !MESSAGE
> +++ Warning +++: Mon Jul 11 12:26:03 CEST 2005 Bad Object: int:
> =OP-Bearbeitung/src< com.bmw.nasa.gui.verwaltung.oplist{CopyOfOpListConfirmationD etailsPanel.java[CopyOfOpListConfirmationDetailsPanel~fireAp plied~QApplyEvent;^currentSize
> !ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 12:26:03.664
> !MESSAGE
> +++ Warning +++: Mon Jul 11 12:26:03 CEST 2005 Skipping expression:
> voucherComboBox.setModel(new DefaultComboBoxModel(VOUCHER_OPTIONS))
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 12:26:03.680
> !MESSAGE
> !ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 12:26:03.695
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.jem.proxy 4 0 2005-07-11 12:26:04.148
> !STACK 0
> java.io.EOFException
> at java.io.DataInputStream.readByte(Unknown Source)
> at
> org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1243)
> at
> org.eclipse.jem.internal.proxy.common.remote.ExpressionComma nds.sendSyncCommand(ExpressionCommands.java:261)
> at
> org.eclipse.jem.internal.proxy.remote.REMConnection.sync(REM Connection.java:320)
> at
> org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:970)
> at
> org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
> at
> org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:311)
> at
> org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:2049)
> !ENTRY org.eclipse.ve.java.core 2 0 2005-07-11 12:26:04.148
> !STACK 0
> java.lang.IllegalStateException: IWAV0173I Command Exception occurred. See
> .log file for details.
> at
> org.eclipse.jem.internal.proxy.remote.REMExpression.throwIll egalStateException(REMExpression.java:193)
> at
> org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:1001)
> at
> at
> at
> !ENTRY org.eclipse.jem.proxy 2 0 2005-07-11 12:26:04.367
> !MESSAGE
> +++ Warning +++: Mon Jul 11 12:26:04 CEST 2005 Project
> (OP-Bearbeitung)-VM for OP-Bearbeitung:err>
> java.lang.NoSuchMethodError
> at
> org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.processException(ExpressionProcesser.java:236)
> at
> org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushMethodInvocation(ExpressionProcesser.java:2598)
> at
> org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(ExpressionProcesserController.java:297)
> at
> org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(ConnectionHandler.java:602)
> at
> org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:493)
> at
> org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
> "Peter Walker" <walkerp@us.ibm.com> schrieb im Newsbeitrag
> news:dalv36$kja$1@news.eclipse.org...
>> Stephan,
>> I20050630?
>> I20050630.
>> information.
>> can debug the problem.
>> Thanks...
>> Peter Walker
>> VE Development
>>> Hi,
>>> latest version of the VE, and tried out a couple of the examples, and
>>> everything seems fine, much better to work with than with WSAD 5.1.
>>> been developed in WSAD 5.1 (and therefore i assume with VE 0.5.0, as i
>>> didn't update it), all i get is a NullPointerException:null
>>> might get on the road to solving this problem
>>> Thanks in advance
>>> Sok
Re: Migrating Visual classes from Websphere to Eclipse [message #609010 is a reply to message #96824] Fri, 08 July 2005 09:29 Go to previous message
Stephan,
debug the problem.
Thanks...
Peter Walker
VE Development
> Thanks in advance
> Sok
Re: Migrating Visual classes from Websphere to Eclipse [message #609021 is a reply to message #97008] Mon, 11 July 2005 06:40 Go to previous message
Hi Peter,
Stephen
!STACK 0
Wrapped exception
Wrapped by
!MESSAGE
accountNumber
!MESSAGE
accountNumber{1}
!MESSAGE
!MESSAGE
!MESSAGE
!MESSAGE
!STACK 0
!MESSAGE
Re: Migrating Visual classes from Websphere to Eclipse [message #609022 is a reply to message #97146] Mon, 11 July 2005 07:00 Go to previous message
Hi again,
EMF 2.1.0
Stephen
> Hi Peter,
> follows;
> Stephen
> !MESSAGE
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> !MESSAGE
> at
> at
> at
> at
> at
> at
>> Stephan,
>> I20050630?
>> I20050630.
>> information.
>> Thanks...
>> Peter Walker
>> VE Development
>>> Hi,
>>> Thanks in advance
>>> Sok
Previous Topic:VE installation & Eclipse 3.1 vs 3.0
Next Topic:VE installation & Eclipse 3.1 vs 3.0
Current Time: Wed Nov 05 00:20:16 EST 2025
Powered by FUDForum. Page generated in 0.06048 seconds
