Home » Eclipse Projects » GEF » Dragging objects from the Outline view to a GEF editor?
Dragging objects from the Outline view to a GEF editor? [message #96398] Tue, 30 September 2003 16:29 Go to next message
Hi there,
Which steps are required so that I can drop ANY selection from ANY view onto
a GEF editor/viewer (especially from the outline view to the GEF editor)? I
have tried to attach a TransferDropTargetListener and use the
LocalSelectionTransfer instance to specify which type of transfers I am
interested in. For some reason, though, I never get the drop cursor on my
editor. What am I missing? It is my understanding that drag and drop
requires drag listeners on one view and drop listeners on the other view.
But do I have to attach these drag listeners on all other views myself?
Aren't they already initialized with a couple of drag listeners? How do I
find out which drag listeners (with which transfer type) are attached to
them?
Dirk
// in my editor
GetGraphicalViewer().addDropTargetListener(new MyListener());
// drop listener class
Class MyListener extends AbstractTransferDropTargetListener {
public MyListener(EditPartViewer viewer) {
super(viewer, LocalSelectionTransfer.getInstance());
public void handleDrop() {
System.out.println("Never get to see this system.out");
Re: Dragging objects from the Outline view to a GEF editor? [message #96474 is a reply to message #96398] Tue, 30 September 2003 22:05 Go to previous messageGo to next message
Originally posted by: selpin.yahoo.com
It seems that you only took care of the editor part, how about the viewer?
did you add the relevant DragSourceAdapter or DragSourceListener?
Dirk Lemmermann wrote:
> Hi there,
> them?
> Dirk
> // in my editor
Re: Dragging objects from the Outline view to a GEF editor? [message #96503 is a reply to message #96474] Wed, 01 October 2003 02:10 Go to previous messageGo to next message
That's exactly my question. Do I need to add drag listeners myself to any
view that I want to support with drag operations? The Navigator for example
already supports dragging operations. Shouldn't I be able to drag something
from there to my viewer?
Dirk
On 10/1/03 4:05 AM, in article bldcpv$pv4$1@eclipse.org, "Evon"
>> Hi there,
>> them?
>> Dirk
>> // in my editor
Re: Dragging objects from the Outline view to a GEF editor? [message #96548 is a reply to message #96503] Wed, 01 October 2003 09:58 Go to previous messageGo to next message
If you know the view already has a drag source for *exactly* the Transfer
you want, there is nothing to do. Otherwise, you need to add the
DragSourceListener yourself.
"Dirk Lemmermann" <dirk@dlsc.com> wrote in message
news:BBA03C6C.2223%dirk@dlsc.com...
example
something
> Dirk
viewer?
> >> Hi there,
onto
editor)? I
my
view.
I
to
> >> them?
> >> Dirk
> >> // in my editor
Re: Dragging objects from the Outline view to a GEF editor? [message #96649 is a reply to message #96548] Wed, 01 October 2003 13:51 Go to previous messageGo to next message
In the case of the (Java) Navigator I already know that it supports
dragging. Is it doucmented somehwere which view supports which drag
operation? Is it a problem if I add a second drag listener of the same type?
Will DnD events be created twice?
Dirk
On 10/1/03 3:58 PM, in article blemdn$cor$1@eclipse.org, "Randy Hudson"
> example
> something
>> Dirk
> viewer?
>>>> Hi there,
> onto
> editor)? I
> my
> view.
> I
> to
>>>> them?
>>>> Dirk
>>>> // in my editor
Re: Dragging objects from the Outline view to a GEF editor? [message #96680 is a reply to message #96649] Wed, 01 October 2003 20:08 Go to previous message
news:BBA0E0AD.2236%dirk@dlsc.com...
Ask on eclipse.tools.jdt
type?
Probably not. Both drag sources will be active during the drag, but when
the drop happens, the first one added will be the one performing setData.
We based our DelegatingDragSourceAdapter on JDT's :-).
No
> Dirk
Transfer
any
> > example
> > something
> >> Dirk
> > viewer?
> >>>> Hi there,
view
> > onto
> > editor)? I
am
on
> > my
> > view.
myself?
do
> > I
> > to
> >>>> them?
> >>>> Dirk
> >>>> // in my editor
Previous Topic:feedback in tree viewers while dragging elements
Next Topic:setting page/editor label
Current Time: Fri Oct 24 20:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.03323 seconds
