Home » Modeling » BPEL Designer » Is this possible?
Is this possible? [message #8656] Fri, 29 June 2007 05:49 Go to next message
Originally posted by: namhun1.naver.com
hi, I'm trying to add a plugin to your BPEL Designer.
I want to implement and add a wizard which helps users with merging or
spliting any process to BPEL Designer.
Is it possible to add such a plugin?
If it is possible, should I use eclipse frameworks like EMF or GEF??
I'll be very pleased if you answer this question clearly.
Thanks.
Re: Is this possible? [message #8721 is a reply to message #8656] Thu, 05 July 2007 21:12 Go to previous message
Michal Chmielewski is currently offline Michal ChmielewskiFriend
Member
Cool.
Yes.
The entire BPEL model, the WSDL, and XSD models are handled by EMF. You
should have access to the model.
GEF is used to display the process map, not necessarily part of any
wizardry you might be building.
If for instances, you wanted to implement
1)select a scope
2) make it a sub-process
then you can certainly do that without any knowledge of GEF. You would
however, have to know something about EMF and resource sets.
This certainly would follow under things like refactoring ... and any
work you would do would be a welcome addition to the BPEL designer.
-m
> Thanks.
Previous Topic:GMF?
Next Topic:BPEL Designer
Current Time: Thu Dec 26 15:06:48 GMT 2024
Powered by FUDForum. Page generated in 0.03047 seconds
