Re: Using EGit - basics [message #481587 is a reply to message #8620] |
Fri, 21 August 2009 16:40 |
Originally posted by: eclipse.johnandcailin.com
I also see this same behavior.
When I try to do Team -> Add to Version Control on any file, I get a popup
error window that is empty. The title of the error window is "Track fail".
No corresponding error message appears in the Eclipse error log (at
metadata/.plugins/org.eclipse.ui.workbench/log).
I see this same behavior on both Eclipse 3.4 and Eclipse 3.5.
Re: Using EGit - basics [message #481603 is a reply to message #481587] |
Fri, 21 August 2009 17:54 |
Sorry, I also should have mentioned the following :
1. This is eGit on Windows Vista with either Eclipse 3.4 and Eclipse 3.5
2. The directory structure is as follows
EclipseWorkRoot
/git-demo
.git
README.txt
/demo
README.txt
I can't add either of the README.txt or the /demo folder to source control.
The internals of my .git directory look healthy, showing all the usual
sub-directories.
Re: Using EGit - basics [message #483284 is a reply to message #481617] |
Mon, 31 August 2009 21:04 |
Sorry for the delayed reply (vacation). I've followed your instructions
and run eclipsec.exe on the command line. I see the following :
2009-08-31 10:38:12.144::INFO: jetty-6.1.11
2009-08-31 10:38:12.146::INFO: Started SocketConnector@127.0.0.1:8501
2009-08-31 10:38:12.153::INFO: Started SocketConnector@127.0.0.1:8601
org.spearce.jgit.errors.ObjectWritingException: Unable to create new
object: M:\
WorkRoot\git-demo\.git\objects\e6\9de29bb2d1d6434b8b29ae775a d8c2e48c5391
org.spearce.jgit.lib.ObjectWriter.writeObject(ObjectWriter.j ava:397)
org.spearce.jgit.lib.ObjectWriter.writeBlob(ObjectWriter.jav a:128)
org.spearce.jgit.lib.ObjectWriter.writeBlob(ObjectWriter.jav a:110)
at org.spearce.jgit.lib.GitIndex$Entry.<init>(GitIndex.java:385)
at org.spearce.jgit.lib.GitIndex.add(GitIndex.java:167)
org.eclipse.egit.core.op.TrackOperation.run(TrackOperation.j ava:117)
at org.eclipse.egit.ui.internal.actions.Track$1.run(Track.java: 41)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(Modal
Context.java:121)
FUDForum. Page generated in 0.05169 seconds
