Home » Eclipse Projects » Mylyn » Changesets and SVN
Changesets and SVN [message #8586] Thu, 05 July 2007 14:40 Go to next message
David Goodenough is currently offline David GoodenoughFriend
I am a long term Eclipse user, but had missed out on Mylyn. When I
installed Europa I was looking through the new goodies and found Mylyn
and thought it looked interesting.
We use Trac and Subversion (with Subclipse). I have the connector
to the trac server working, and subclipse works, but I am having a
problem understanding what I have to do to get changesets working. If
it matters I am running under Linux (KDE Debian-sid) with Sun Java 6.
I found the Mylyn_User_Guide, and got to the bit about changesets.
Well the first bit I found was under Eclipse Settings, Team, first bullet.
If I go into the syncronize view I do not see toolbar button Show Change
Sets (what is it supposed to look like?).
Then under submitting contexts it says to Attach the context, which I did
but nothing changed.
As I am running SVN I understand under the Team Support section that
Subclipse only supports standard mode. But I do not understand the
significance of this.
Also I am unclear about how I put something into a changeset, and how
I then check in the whole lot at once.
I thought that Mylyn just noticed that I was working on a task, watched
that I was doing and noticed that I had changed some local files, and then
when I checked them in (maybe I checked in the wrong thing) would submit
the whole changeset.
I guess I missed something.
David
Re: Changesets and SVN [message #8595 is a reply to message #8586] Thu, 05 July 2007 14:43 Go to previous messageGo to next message
Originally posted by: mphippard.collab.net
Have you installed Subclipse 1.2.3 and the Subclipse/Mylyn connector 2.0.0
both are necessary and on the Subclipse update site.
Other than that, all you have to do is click the Changeset icon in the
Synchronize view so that it is showing change sets.
Mark
On 7/5/07 10:40 AM, in article f6ivt8$4o3$1@build.eclipse.org, "David
> David
Re: Changesets and SVN [message #8605 is a reply to message #8595] Thu, 05 July 2007 15:36 Go to previous messageGo to next message
Yes I have those installed, my problem is knowing what this Changeset icon
is and where to find it. I also think that I am possible not following
the correct workflow so that Mylyn knows that I am starting to work on
a new task. In my simply minded way I just closed all open editors, opened
the task object, opened the ticket and using the Package Explorer started
opening source files. I made some changes and normally I would just
check them back into SVN in the normal way one at a time. I have
Package Explorer set up to show the active files only, and if I do
a Team -> Commit from there I get a message box saying it is doing something
with the ticket, but then when the SVN Commit dialog opens the commit
message has not been filled in as it seemed to be on the video I watched.
David
> Mark
>> bullet. If I go into the syncronize view I do not see toolbar button Show
>> Change Sets (what is it supposed to look like?).
>> then when I checked them in (maybe I checked in the wrong thing) would
>> submit the whole changeset.
>> David
Re: Changesets and SVN [message #8625 is a reply to message #8605] Mon, 09 July 2007 07:07 Go to previous messageGo to next message
Dave Syer is currently offline Dave SyerFriend
Member
Is the "Automatically create and manage with task content" checkbox ticked
and do you have a commit comment template in the
Window->Preferences->Mylyn->Team tab?
You can check a tasks context in flight if you open it up and go to the
context tab (the tab is on the bottom of the pane). If there is a context
then there is probably a change set - as long as your project is actually
under source control (and Sunclipse knows about it of course).
The change set icon looks like a little document with a Mylyn "lambda" icon
over it. In my case it show up on the far right of the Synchronize tab
toolbar, next to the red double arrow for "conflicts mode".
"David Goodenough" wrote in message news:...
> something
> David
> > 2.0.0
> > Mark
> >> Show
> >> did
> >> David
-- Dave SyerPrincipal ConsultantInterface21 - the company behind SpringTel:
+44 (0) 20 8691 7876Mob: +44 (0) 7801 737
939david.syer@interface21.comhttp://www.interface21.comhttp: //www.springframework.orgRegistered
in England and Wales: registration number 5187766Registered Office: A2
Yeoman Gate, Yeoman Way, Worthing, West Sussex, BN13 3QZThis e-mail and any
attachments transmitted with it are strictly confidential and intended
solely for the person or entity to whom they are addressed. Unauthorised
use, copying, disclosure or distribution is prohibited. If you receive this
e-mail in error please notify the sender immediately and then delete it
along with any attachments. E-mails should be checked by the recipient to
ensure that there are no viruses and Interface21 does not accept any
responsibility if this is not done. Any views or opinions presented are
solely those of the author and do not necessarily represent those of
Interface21.
Re: Changesets and SVN [message #8634 is a reply to message #8605] Mon, 09 July 2007 08:58 Go to previous message
Maybe you miss to "activate" the task (right click on a task in the task
view => "Activate")?
Mauro.
Re: Changesets and SVN [message #569860 is a reply to message #8586] Thu, 05 July 2007 14:43 Go to previous message
Mark Phippard is currently offline Mark PhippardFriend
Mark
> David
Re: Changesets and SVN [message #569884 is a reply to message #8595] Thu, 05 July 2007 15:36 Go to previous message
David
> Mark
>> David
Re: Changesets and SVN [message #569952 is a reply to message #8605] Mon, 09 July 2007 07:07 Go to previous message
Member
> something
> David
> > 2.0.0
> > Mark
> >> Show
> >> did
> >> David
Interface21.
Re: Changesets and SVN [message #570030 is a reply to message #8605] Mon, 09 July 2007 08:58 Go to previous message
Mauro Molinari is currently offline Mauro MolinariFriend
Mauro.
Previous Topic:Extension points definition
Next Topic:notifications for local tasks changes
Current Time: Sat Nov 09 00:08:28 GMT 2024
Powered by FUDForum. Page generated in 0.04090 seconds
