Error executin tag handler [message #8567] |
Sat, 31 March 2007 20:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dmachak.xxxx.com
I'm getting the following error while trying to run the default
tranformation in a new EMFT Jet Transformation project:
templates/dump.jet(3,1): <c:dump entities="true" format="true"
select="/*">
Error: Error executing tag handler: java.lang.NullPointerException
I'm running Eclipse 3.2.1, with EMF 2.3.0 and JET 0.7.100.
All I'm doing is selecting sample.xml and selecting Run As... input for
JET transformation.
Is there something I'm doing wrong, or is this a problem with my
combination of versions?
Thanks for any help you can give.
Dan
Re: Error executin tag handler (Nevermind) [message #9751 is a reply to message #8567] |
Sat, 31 March 2007 21:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I upated to the JET 0.7.2 release, and it looks like its working now. I
had originally downloaded the version 0.8.0 archive, but the plugins in
that archive had a version of 0.7.1.
FUDForum. Page generated in 0.05624 seconds
