Re: D&D of components [message #8542 is a reply to message #8415] |
Tue, 08 August 2006 02:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: khai.n.situvista.com
In the NodeMapping for your 'container' node in .gmfmap do you have
Compartment Mapping(s). If so then have you added all the appropriate
'child' nodes into the Compartment?
-- Khai --
Barry Dresdner wrote:
> I have configured my ecore model to indicate which components can contain
> other components, but when I drag an item from the palette over a component
> that I have indicated an element that can contain the selected palette item,
> the drop icon is disabled (I get the circle with a slash through it). Is
> there an easy way to debug this problem? What determines that when the drop
> icon should be enabled?
> thanks - Barry
FUDForum. Page generated in 0.03677 seconds
