| Classpath entries for Plugin unit test [message #8378] | Wed, 25 June 2008 11:39 |  |
| Eclipse User  |  |  |  |  | Hi,
 I created a plugin with JUnit tests that uses com.sun.tools.javac.Main
 in the code to compile classes. Main is located in the tools.jar of my
 JDK.
 So in my plugin project, I set a variable to my JDKs tools.jar, and added
 that variable to the build path of the project. The project builds fine.
 However, when I run the Plugin JUnit test, I get this exception below.
 Now I am sure there is a way I can get this to run, maybe by changing
 something in the launch configuration for the Plugin test. Can anyone tell
 me what to do?
 java.lang.NoClassDefFoundError: com/sun/tools/javac/Main
 test.util.ParserGenerationTestHelper.compileParser(ParserGen erationTestHelper.java:67)
 Caused by: java.lang.ClassNotFoundException: com.sun.tools.javac.Main
 at java.lang.ClassLoader.findClass(ClassLoader.java:358)
 at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
 at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
 at  java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
 ... 45 more
FUDForum. Page generated in 0.04504 seconds
