How to gain gridlayout like functionality [message #92965] |
Mon, 08 September 2003 14:29 |
Originally posted by: anders.soderman.home.se
I am trying to make it possible to add children to a parent container in a
gridlayout type of style.
The parent container should have rows and columns which makes a coordinate
system so if for example
we have rows=2 columns = 2 the figure should look like this
| 0,0 | 0,1 |
| 1,0 | 1,1 |
When you drag a palette item and drop it on e.g 1,0 that square should size
if needed and
the model should be able to know where it was dropped.
This is almost like a flowlayout with one more dimension.
What is the preferred way of designing this behaviour. I would prefer a
solution that affects the model the least
since this is a presentaion thing. I have tried going the editpart way but
it seems to me that it shouldn't have to be this complicated.
Thanks Anders
Re: How to gain gridlayout like functionality [message #93334 is a reply to message #92965] |
Wed, 10 September 2003 14:25 |
To do this, you need to write your own draw2d layoutmanager, and GEF
constrainedLayoutEditPolicy which interpret's drop locations and generates
the right commands for placing the objects in the corresponding row/column.
You also need to store the row/column data in your model somewhere.
"Anders S
FUDForum. Page generated in 0.03328 seconds
