Internal Error during "Create Remote VM"? [message #92094] |
Thu, 26 May 2005 10:24  |
Originally posted by: jimwperkins.gmail.com
Hi All,
I've setup Ecliplse 3.1m7 and run the updates (via help/software update)
to get the VE up and runing. When I try to bring one of my visual jave
projects up, I get a series of error popups. The error messages are:
first & second popup) An internal error occured during: "Create Remote VM
for Visual Editor for Java"
third popup) An internal error occured during: "Setup Java Visual Editor".
I have both j2re1.4.2 and jre1.5.0_03 installed and have switched between
then (in the project settings), but the errors are the same.
Could someone who understands Java better than I do (not hard:-) help me
fix the problem?
JIm
Re: Internal Error during "Create Remote VM"? [message #92107 is a reply to message #92094] |
Thu, 26 May 2005 10:42  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
3.1M7 doesn't work with any of the released VE levels available through
update manager. Since 3.1 is not a released level yet and neither is VE
1.1 released for working with 3.1, they are only available as manual
development driver downloads.
For VE we do not have any integration builds for M7 yet. We should have
one out by end of today. At that time you can pick it up.
Rich Kulp
Re: Internal Error during "Create Remote VM"? [message #607830 is a reply to message #92094] |
Rich Kulp
FUDForum. Page generated in 0.02731 seconds
