Re: Help on Capturing Max or Min event of Editor [message #92052 is a reply to message #91934] |
Fri, 11 July 2003 18:27 |
Originally posted by: simon.ibm.oti.lab
There is no API to do that
Simon :-)
"Chinh Hoang" <choang@ca.ibm.com> wrote in message
news:bemr69$591$1@eclipse.org...
> Hi. My Editor needs to do somethings when it is being Maximized/Restore.
> Can somebody point me the the classes and the methods that I need to
> extends/override.
> To Maximize an editor u normal just double click on the header of the
> editor. To restored to non-maximized you can double click on the header of
> the editor again.
> Thanks
Re: Help on Capturing Max or Min event of Editor [message #93092 is a reply to message #93078] |
Mon, 14 July 2003 14:08 |
No plan to add this type of API. You can open a bug report against
Platform - UI to make your request. Include a detail description of your use
case (maybe with a couple of screen shots)
Simon :-)
news:beuckr$tko$1@eclipse.org...
> Are there any plans to? The reason why I trying to listen to these events
> or some how extend that code is because i am implementing a feature for my
> editor that understands when to put its palette inside of the pallette
> viewer when the palette viewer is visible or inside the editor inside the
> edtitor itself when the palette viewer is not.
> > Simon :-)
Maximized/Restore.
> > > extends/override.
header of
> > > the editor again.
> > > Thanks
FUDForum. Page generated in 0.02755 seconds
