GMF Tutorial BPMN: svg custom figure does not work [message #91911] |
Fri, 12 January 2007 11:32 |
Originally posted by: martin.tauber.t-online.de
I'm trying to create a custom figure as described in the GMF Tutorial
BPMN, but the figure just draws a read box (I guess which should
indicate problesm rendering the figure). I saw BUG139130 which
recommands to add the xerces plugin. But this didn't move me foward as
well (Well the bug as I interprete is also should have been fixed I'm
using version 1.0.1 of gmf.
Any other Ideas?
Martin
Re: GMF Tutorial BPMN: svg custom figure does not work [message #92115 is a reply to message #91911] |
Fri, 12 January 2007 13:20 |
Originally posted by: 5d5.mail.ru
Checkout TaiPan sample project - it uses svg figure for 'empty box' item
inside 'ship'; if you can't see it - it's configuration problem with
your workbench; otherwise see how it's implemented.
Martin Tauber wrote:
> Hi
> Any other Ideas?
> Regards
> Martin
FUDForum. Page generated in 0.03391 seconds
