Home » Eclipse Projects » GEF » Problems with figure's parent
| Problems with figure's parent [message #91739] |
Fri, 29 August 2003 21:11   |
Eclipse User  |
Originally posted by: gg.decisionsoft.co.uk
I am implementing an action that positions the children of a freeform layer when run.
I am having problems with the following line of code:
 childPart.getFigure().getParent().setConstraint(childPart.ge tFigure(), new Rectangle(hOffset, vOffset, -1, -1));
This is throwing a null point exception as the figure's parent is null, but the figure appears in the display within the parent figure. What's wrong?
I have also tried:
getFigure().setConstraint(childPart.getFigure(), new Rectangle(hOffset, vOffset, -1, -1));
from within the parent edit part, but this produces "Figure.setConstraint(..): Figure is not a child"
Geoff
| Re: Problems with figure's parent [message #91789 is a reply to message #91739] |
Fri, 29 August 2003 10:13    |
Eclipse User  |
Where are you running this code from?  Hopefully not inside the action or a
command.  Are you running this code inside your refresh()?
"Geoff Gibbs" <gg@decisionsoft.co.uk> wrote in message
news:binjdu$m6p$1@eclipse.org...
layer when run.
wrong?
> I have also tried:
vOffset, -1, -1));
> Geoff
| Re: Problems with figure's parent [message #91815 is a reply to message #91789] |
Fri, 29 August 2003 22:49   |
Eclipse User  |
Er. Yes. It's being run from an action.
Is that a bad thing?
Where should I be putting the code for an action that repositions figures?
> layer when run.
> wrong?
>>I have also tried:
> vOffset, -1, -1));
Geoff
| Re: Problems with figure's parent [message #91860 is a reply to message #91815] |
Fri, 29 August 2003 13:22   |
Eclipse User  |
news:binp5m$sn1$1@eclipse.org...
or a
Well, how are you persisting the figure's locations?  Their locations should
be stored in the model.  The model's values should be reflected (copied)
into the figures, but that is not where you should store them.
If you delete an object, and undo the delete, a new editpart and new figure
are created, so you'll have to use the model to retain location info.
Perhaps you started using GEF more than a month ago.  Recently, we've
published a tutorial on GEF that explains these concept.  Please see our
homepage.
> > layer when run.
new
> > wrong?
> >>I have also tried:
> > vOffset, -1, -1));
> Geoff
 Current Time: Tue Nov 04 09:53:51 EST 2025
 Powered by  FUDForum. Page generated in 0.04899 seconds
