Re: how to create two linked element in a diagram related to a single element in the model [message #33828 is a reply to message #8248] |
Wed, 30 August 2006 08:26 |
Originally posted by: strommer.big.tuwien.ac.at
i have i similar problem. do you have already found a solution for your
problem?
Michele Puccio schrieb:
> Hi all
> I want to map the UML AssociationClass in my UML Class Diagram Editor. I
> n the gmfmap I mapped the AssociationClass as a linkMapping; the link in
> the diagram editor is correctly created. A class is also created because
> the AssociationClass is a Class (that is mapped as a rectangle with
> compartments). So I want to create a connection between the link and the
> class: I'm able to do this using *note attachment* from the palette but
> I would create this attachment programmatically.
> Any idea/suggestions?
> thanks
> michele
> | A |---------------| B |
> | C |
FUDForum. Page generated in 0.03305 seconds
