Error opening class files [NEWBIE] [message #91565] |
Fri, 11 July 2003 02:31  |
Originally posted by: movingtomac.hotmail.com
Heeelp!!! =(
I'm new to Eclipse. I am trying to move from ProjectBuilder, on Mac OS X,
to Eclipse. I have it installed with the WOLips project. When I attempt to
double-click on any class file, or open it using the "Class File Viewer" I
receive the following error and nothing opens:
The classfile is not on the class path.
Could someone please tell me what is probably wrong and how to fix it? The
more idiot-proof the answer is, the better.
"Bill"
Re: Error opening class files [NEWBIE] [message #91612 is a reply to message #91565] |
Fri, 11 July 2003 03:10  |
Originally posted by: daniel.megert.gmx.net
Goodbye Bill wrote:
>Heeelp!!! =(
What kind of class file is it? Is it from a library or is it generated
from one of your .java source files? If it is a class file from a
library then you have to ensure that this file is on the Java build path
(open your project's properties > Java Build Path). If the class file is
generated then you should not open it in the first place. Open the
corresponding .java source file. Note: also the source file needs to be
on the Java build path.
Dani
FUDForum. Page generated in 0.03360 seconds
