Re: No suitable Log constructor error [message #91721 is a reply to message #91592] |
Sun, 08 July 2007 14:05 |
Marcos Pereira Messages: 4 Registered: July 2009 |
Junior Member |
Hi Simon,
Thank you very much for the hints. I tried 2) and 3) (unfortunately I
couldn't drop log4j dependency, so 1) was not an option for me).
Bad news is that neither 2) and 3) worked too. However, looking into SLF4J
pattern I had the idea to build a log4j wrapper in same way as
jcl-over-slf4j and that finally worked. I added some code snippet below, but
I can provide the full solution for anyone interested.
Anyway, your hints pointed me to a solution. Thanks!
Marcos
package org.apache.log4j;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
public class Logger {
private Log log;
private Logger(Class clazz) {
log = LogFactory.getLog(clazz);
private Logger(String name) {
log = LogFactory.getLog(name);
public static Logger getLogger(Class clazz) {
return new Logger(clazz);
public void debug(Object message) {
System.out.println("DEBUG: " + message);
log.debug(message);
public void debug(Object message, Throwable t) {
log.debug(message, t);
"Simon Kaegi" <simon_kaegi@ca.ibm.com> escreveu na mensagem
news:f6j80l$p1q$1@build.eclipse.org...
> Hi Marcos,
> Please open a bug for this - this is going to be tough to deal with.
> The problem here is that your use of log4j in your jsp is being leaked via
> the context class loader into the jasper implementations use of commons
> logging.
> The commons logging discovery process will find log4j on the CCL but not
> in it's own class hierarchy and will then run into problems.
> I can think of two workarounds:
> 1) Remove your direct dependency on log4j from your jsp bundle and instead
> move it to another bundle you can call from your jsp.
> 2) If you're in full control of your platform add a fragment to the
> commons.logging bundle that imports log4j
> 3) Take a look at SLF4J and jcl-over-slf4j and create bundles to replace
> the commons.logging bundle.
> HTH
> -Simon
> "Marcos Pereira" <marcos-luiz@ig.com.br> wrote in message
> news:f6hmf2$3dp$1@build.eclipse.org...
>> Hi all.
>> I have been testing the JSP Examples Bundle found at:
>> http://www.eclipse.org/equinox/server/jsp_support.php
>> It works fine without changes, but when I try to add a dependency to
>> org.apache.log4j (either as Import-Package or Require-Bundle) the error
>> below throws out.
>> Any clue about how to fix this? I checked either on this group and on
>> Eclipse bugzilla but unfortunately I wasn't able to find a solution so
>> far.
>> org.apache.commons.logging.LogConfigurationException:
>> org.apache.commons.logging.LogConfigurationException: No suitable Log
>> constructor [Ljava.lang.Class;@ff2413 for
>> org.apache.commons.logging.impl.Log4JLogger (Caused by
>> java.lang.NoClassDefFoundError: org/apache/log4j/Category) (Caused by
>> java.lang.NoClassDefFoundError: org/apache/log4j/Category))
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:543)
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:235)
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:209)
>> at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :351)
>> at
>> org.apache.jasper.EmbeddedServletOptions.<init>(EmbeddedServletOptions.java:43)
>> at org.apache.jasper.servlet.JspServlet.init(JspServlet.java:97 )
>> at org.eclipse.equinox.jsp.jasper.JspServlet.init(JspServlet.ja va:81)
>> at
>> org.eclipse.equinox.http.helper.ContextPathServletAdaptor.in it(ContextPathServletAdaptor.java:31)
>> at
>> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.init(ServletRegistration.java:64)
>> at
>> org.eclipse.equinox.http.servlet.internal.ProxyServlet.regis terServlet(ProxyServlet.java:140)
>> at
>> org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.re gisterServlet(HttpServiceImpl.java:50)
>> at
>> org.eclipse.equinox.jsp.examples.Activator$HttpServiceTracke r.addingService(Activator.java:48)
>> at
>> org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
>> at
>> org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
>> at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
>> at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
>> at org.eclipse.equinox.jsp.examples.Activator.start(Activator.j ava:26)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
>> at java.security.AccessController.doPrivileged(Native Method)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
>> at
>> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
>> at
>> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
>> at
>> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
>> at
>> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
>> at
>> org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
>> at
>> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
>> at
>> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
>> Caused by: org.apache.commons.logging.LogConfigurationException: No
>> suitable Log constructor [Ljava.lang.Class;@ff2413 for
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:413)
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:529)
>> ... 29 more
>> Caused by: java.lang.NoClassDefFoundError: org/apache/log4j/Category
>> at java.lang.Class.getDeclaredConstructors0(Native Method)
>> at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
>> at java.lang.Class.getConstructor0(Unknown Source)
>> at java.lang.Class.getConstructor(Unknown Source)
>> at
>> org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:410)
>> ... 30 more
Re: No suitable Log constructor error [message #91734 is a reply to message #91721] |
Sun, 08 July 2007 14:46 |
Junior Member |
The bug entry #195765 was added to Eclipse bugzilla, regarding this topic.
Link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=195765
Marcos
"Marcos Pereira" <marcos-luiz@ig.com.br> escreveu na mensagem
news:f6qr01$eoe$1@build.eclipse.org...
> Hi Simon,
> but I can provide the full solution for anyone interested.
> Marcos
> private Log log;
> log.debug(message);
>> Hi Marcos,
>> via the context class loader into the jasper implementations use of
>> commons logging.
>> instead move it to another bundle you can call from your jsp.
>> HTH
>> -Simon
>>> Hi all.
>>> below throws out.
>>> far.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> at
>>> ... 30 more
Re: No suitable Log constructor error [message #91749 is a reply to message #91734] |
Sun, 08 July 2007 14:49 |
Simon Kaegi Messages: 381 Registered: July 2009 |
Thanks Marcos.
I'm definitely interested in your approach if you want to add it as
attachment to the bug.
-Simon
news:f6qtc2$jbb$1@build.eclipse.org...
> Marcos
>> Hi Simon,
>> SLF4J pattern I had the idea to build a log4j wrapper in same way as
>> Marcos
>> private Log log;
>> log.debug(message);
>>> Hi Marcos,
>>> commons logging.
>>> HTH
>>> -Simon
>>>> Hi all.
>>>> below throws out.
>>>> far.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 29 more
>>>> at
>>>> ... 30 more
Re: No suitable Log constructor error [message #102885 is a reply to message #91734] |
Sat, 15 December 2007 12:17 |
Originally posted by: scof.optonline.net
I'm experiencing a similar problem. Very insidious; I struggled for a long time before stumbling on this thread. My ultimate solution was to create a fragment for the commons-logging bundle.
You've entered a bug for this against eclipse, but it seems to me this is a commons-logging issue rather than a eclipse one, no?
FUDForum. Page generated in 0.04284 seconds
