Home » Language IDEs » Java Development Tools (JDT) » Debugger apparently does not work
Debugger apparently does not work [message #8214] Tue, 29 April 2003 07:44 Go to next message
Originally posted by: markus.rakowski.nospam-gmx.net
I have installed the eclipse-SDK-2.1-win32.zip. I am able to compile and
run aplications without problems. But if try to debug, eclipse changes
to the debug perspective but nothing more seems to happen. The menus
Resume, Suspend, Terminate, ... are all grayed.
The system is Windows XP, SDK 1.4.2 beta. Same happens with 1.4.1.
Could anyone, please, tell me what I am missing?
I appreciate your help.
Thanks.
Re: Debugger apparently does not work [message #8305 is a reply to message #8214] Tue, 29 April 2003 09:41 Go to previous messageGo to next message
Originally posted by: faust.acm.org
Have you set a breakpoint?
Randy
"Markus Rakowski" <markus.rakowski@nospam-gmx.net> wrote in message
news:b8lagt$d5c$1@rogue.oti.com...
> Thanks.
Re: Debugger apparently does not work [message #15895 is a reply to message #8305] Tue, 06 May 2003 22:19 Go to previous message
Originally posted by: stefan.schulz.sbcglobal.net
I have the same problem and my configuration is similar:
+ Windows XP
+ JDK 1.4.1_02
+ Eclipse 2.1
The program runs with out any problem.
It jumps into the debug perspective (Breakpoints are set)
and stops. It looks like that it stops at the breakpoint
but I can not use the menus Resume, Suspend, Terminate, they are all
grayed.
Thanks for
your help
Stefan
> Randy
>>Thanks.
Previous Topic:Bumping up the Ant heapsize
Next Topic:can't format selections
Current Time: Sat Dec 21 16:54:43 GMT 2024
Powered by FUDForum. Page generated in 0.03248 seconds
