Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Compare] Minor buglet
[Compare] Minor buglet [message #91347] Mon, 23 July 2007 10:23 Go to next message
I have been creating examples in order to demo to ppl here &....
If I have 2 models & they are called different things then the order of
selection makes no difference as the left hand side/right hand side
appears to be determined by alphabetical filename.
Adam
Re: [Compare] Minor buglet [message #91379 is a reply to message #91347] Mon, 23 July 2007 10:52 Go to previous messageGo to next message
--------------080503060101030507040201
Adam,
If this is about EMF Compare (never seen the tag [Compare] before but
you're talking about models so I'll assume this is), we do not take the
order of selection into account for model comparison. As does the
file/text/source/... generic comparison, the left and right hand side of
model comparison will be determined alphabetically.
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #91394 is a reply to message #91379] Mon, 23 July 2007 11:17 Go to previous messageGo to next message
Laurent Goubet wrote:
> Adam,
> Laurent Goubet
> Obeo
>> of selection makes no difference as the left hand side/right hand side
>> Adam
Yes it's [EMF Compare].
I simply assumed that the order of selection was what determined the
left/right etc.
What happens where there are 2 files in different projects etc called
the same thing? File date?
Adam
Re: [Compare] Minor buglet [message #91432 is a reply to message #91394] Mon, 23 July 2007 11:27 Go to previous messageGo to next message
--------------050706010606080306070600
I think the comparison order isn't determined on filename alone, but on
the resource's full path (Two files called exactly the same name cannot
coexist in the same directory). If you would like the behavior to be
different, I think you'll have to ask this on the platform newsgroup for
the compare component as we make use of their API and, thus, inherit
from their behavior.
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #91474 is a reply to message #91432] Tue, 24 July 2007 05:05 Go to previous messageGo to next message
Oh OK will do.
Adam
> Laurent Goubet
> Obeo
>>> Adam,
>>> the order of selection into account for model comparison. As does the
>>> of model comparison will be determined alphabetically.
>>> Laurent Goubet
>>> Obeo
>>>> side appears to be determined by alphabetical filename.
>>>> Adam
>> left/right etc.
>> Adam
Re: [Compare] Minor buglet [message #91488 is a reply to message #91432] Tue, 24 July 2007 05:07 Go to previous message
> Laurent Goubet
> Obeo
Oh & BTW it would appear from this that my original [Compare] was
correct <G>
Adam
Re: [Compare] Minor buglet [message #608852 is a reply to message #91347] Mon, 23 July 2007 10:52 Go to previous message
Adam,
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #608853 is a reply to message #91379] Mon, 23 July 2007 11:17 Go to previous message
> Adam,
> Laurent Goubet
> Obeo
>> Adam
left/right etc.
Adam
Re: [Compare] Minor buglet [message #608855 is a reply to message #91394] Mon, 23 July 2007 11:27 Go to previous message
Laurent Goubet
Obeo
AdamF a
Re: [Compare] Minor buglet [message #608858 is a reply to message #91432] Tue, 24 July 2007 05:05 Go to previous message
Oh OK will do.
Adam
> Laurent Goubet
> Obeo
>>> Adam,
>>> Laurent Goubet
>>> Obeo
>>>> Adam
>> left/right etc.
>> Adam
Re: [Compare] Minor buglet [message #608859 is a reply to message #91432] Tue, 24 July 2007 05:07 Go to previous message
> Laurent Goubet
> Obeo
correct <G>
Adam
Previous Topic:[EMF Compare] Updated XSLT
Next Topic:[EMF Compare] Updated XSLT
Current Time: Wed Apr 16 04:05:52 EDT 2025
Powered by FUDForum. Page generated in 0.04564 seconds
