URLEncoded Directory Paths [message #90814] |
Tue, 19 June 2007 20:03 |
Brett Humphreys Messages: 17 Registered: July 2009 |
Junior Member |
All,
I've got a situation where I'm running equinox in a path that is URL
encoded, but I'm noticing problem (specifically making osgi.bundle
values relative to the syspath), however that led me to a bigger issue
that I can't seem to solve.
If I have the equinox jar in a path with a percent sign in it, equinox
won't start. For example:
$ pwd
/tmp/test%one
$ ls
configuration org.eclipse.osgi_3.2.2.R32x_v20070118.jar
$ java -jar org.eclipse.osgi_3.2.2.R32x_v20070118.jar -console -clean
java.lang.IllegalArgumentException
at sun.net.www.ParseUtil.decode(ParseUtil.java:183)
at sun.net.www.protocol.file.Handler.openConnection(Handler.jav a:63)
at sun.net.www.protocol.file.Handler.openConnection(Handler.jav a:55)
at java.net.URL.openConnection(URL.java:943)
at java.net.URL.openStream(URL.java:1007)
at org.eclipse.core.runtime.adaptor.EclipseStarter.loadProperti es(EclipseStarter.java:1125)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadConfigur ationInfo(EclipseStarter.java:1117)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:274)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:173)
at org.eclipse.core.runtime.adaptor.EclipseStarter.main(Eclipse Starter.java:150)
More specifically, if the percent sign is a valid escaping (ie, if the dir was /tmp/test%20) equinox
will start, however it will fail to find the config.ini that is located in the configuration directory.
I've played games with adding -install, -configuration, -data and -framework to the command line all
with varying degrees of success (for example I would set -configuration to be /tmp/test%25one), the
config.ini was eventually found (I think) but the osgi.bundles option in config.ini wasn't doing
what I expected it to do, nor was a log file being generated in the configuration directory.
Anyone have any thoughts on a work around? I think the issue boils down to the
o.e.c.runtime.internal.adapter.BasicLocation class' setURL method doing:
value = new URL("file:" + basepath) <-- where basepath is not URL encoded
but I'm not 100% sure this is the real core of the issue.
-Brett
FUDForum. Page generated in 0.03454 seconds
