Home » Archived » Visual Editor (VE) » Problems with XML and VE
- Problems with XML and VE [message #90778] Thu, 12 May 2005 04:37 Go to next message
Hi!
I have Eclipse 3.0.2 and VE 1.0.2.1 installed.
Now I tried to open .xml and .dtd files.
I did not work and I got some errors. I attached the .log file.
What can I do to fix this error?
Maja
Error Mai 12, 2005 10:16:10.681 Problems occurred when invoking code from
plug-in: "org.eclipse.core.runtime".
An error has occurred when initializing the input for the the editor's
source page. Original Error: org.eclipse.ui.PartInitException: Editor
could not be initialized.
org.eclipse.wst.xml.internal.ui.XMLMultiPageEditorPart.addSo urcePage(XMLMultiPageEditorPart.java:185)
org.eclipse.wst.xml.internal.ui.XMLMultiPageEditorPart.creat ePages(XMLMultiPageEditorPart.java:231)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:187)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
at org.eclipse.ui.internal.EditorManager$9.run(EditorManager.ja va:969)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:933)
at org.eclipse.ui.internal.EditorManager$8.run(EditorManager.ja va:926)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:922)
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1303)
org.eclipse.ui.internal.EditorManager$Editor.getPart(EditorM anager.java:1295)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:186)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:674)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:66 0)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:94)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.setSelection(DefaultPartPresentation.java:1408)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n$4.handleEvent(DefaultPartPresentation.java:166)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:820)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:805)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 13)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3053)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 17)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:287)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2773)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2432)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
- Re: Problems with XML and VE [message #90881 is a reply to message #90778] Thu, 12 May 2005 10:53 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That has nothing to do with the VE. I don't know what org.eclipse.wst
component is, but they are doing something that conflicts with the VE.
You will need to go to them for the fix.
Maja wrote:
> Hi!
> Maja
> from plug-in: "org.eclipse.core.runtime".
> at
Rich Kulp
- Re: Problems with XML and VE [message #91387 is a reply to message #90778] Tue, 17 May 2005 10:15 Go to previous messageGo to next message
My problem is that I want to use WTP features and the VE in one
project.
Now I've tried to do it the other way round:
I've first installed 'wtp-eclipse-prereqs-sdk-1.0M3-win32' (this
is Eclipse Version 3.1.0) and then VE Version 1.0.2.1.
Now WTP is working fine but VE produces errors when opening a visual
class. Maybe you can help me with that.
Thanks a lot!
!SESSION 2005-05-17 16:03:14.514
eclipse.buildId=I20050219-1500
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2005-05-17 16:03:14.514
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.ui.internal.commands.Command
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:359)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:94)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.enableDelCommand(JavaVisualEditorPart.java:1969)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.focusGained(JavaVisualEditorPart.java:1979)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:104)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1838)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:1914)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:361 5)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:245)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3088 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3480 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:647)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:2121)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:66 2)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setFocus(JavaVisualEditorPart.java:2288)
at org.eclipse.ui.internal.WorkbenchPage$4.run(WorkbenchPage.ja va:574)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:570)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2806)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:559)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2326)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2244)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:2236)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2222)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2217)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2202)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:276)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:268)
org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
- Re: Problems with XML and VE [message #91463 is a reply to message #91387] Tue, 17 May 2005 17:14 Go to previous message
WTP M3 works on Eclipse 3.1M5a. VE 1.0.2.1 doesn't work on that version
of Eclipse. VE 1.1 driver I20050318 works on 3.1M5a. But I don't know if
the JEM out of I20050318 is compatible with WTP M3. You can give it a
try, but be aware it may not work and you might need to reinstall the
WTP M3 without VE to get back to something working.
There is an WTP M4 available that works on Eclipse M6 and that has a JEM
that is compatible with M6, in fact you could use the I20050415 driver
of VE with WTP M4 on Eclipse 3.1M6. Those are all compatible with each
other.
Rich Kulp
- Re: Problems with XML and VE [message #607748 is a reply to message #90778] Thu, 12 May 2005 10:53 Go to previous message
Maja wrote:
> Hi!
> Maja
> at
Rich Kulp
- Re: Problems with XML and VE [message #607783 is a reply to message #90778] Tue, 17 May 2005 10:15 Go to previous message
project.
Thanks a lot!
!STACK 0
- Re: Problems with XML and VE [message #607788 is a reply to message #91387] Tue, 17 May 2005 17:14 Go to previous message
other.
Rich Kulp
Previous Topic:VE N20050516 problems with M7
Next Topic:M7 / GTK / AMD64: not working
Current Time: Mon Apr 28 10:42:15 EDT 2025
Powered by FUDForum. Page generated in 0.57475 seconds
