M6 and JEM [message #90654] |
Thu, 07 April 2005 16:31 |
Originally posted by: mdiggory.apache.org
I'm working to compile the WST Common Navigator out of the CVS head on
Eclipse 3.1M6. I'm noticing that the JEM package released with WTP 1.0M3
isn't compatible with the HEAD anymore (understandable and acceptable).
I'm getting compilation errors, I've been pulling JEM plugins from the
CVS to resolve this. But its difficult to get the full set of
dependencies met. Are there any developers out there who have a list of
the JEM dependencies for the current head?
thanks,
Mark Diggory
Re: M6 and JEM [message #91544 is a reply to message #91473] |
Tue, 12 April 2005 10:42 |
--------------030509050303070203020109
If you're like me and you insist on building from HEAD anyway, the
attached Team Project Set should do the trick...for now.
- Nitin
Content-Type: text/xml;
name="jem-reqs.psf"
Content-Disposition: inline;
filename="jem-reqs.psf"
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem-fea ture/com.ibm.etools.emf.event,com.ibm.etools.emf.event "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem,org .eclipse.jem "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem.bea ninfo,org.eclipse.jem.beaninfo "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem.pro xy,org.eclipse.jem.proxy "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem.ui, org.eclipse.jem.ui "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem.uti l,org.eclipse.jem.util "/>
<project reference=" 1.0,:pserver:dev.eclipse.org:/home/tools,org.eclipse.jem.wor kbench,org.eclipse.jem.workbench "/>
</provider>
</psf>
--------------030509050303070203020109--
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03171 seconds
