Home » Eclipse Projects » DTP » Similar Features...
Re: Similar Features... [message #90 is a reply to message #89] |
Fri, 11 March 2005 16:30 |
Originally posted by: john.graham.sybase.com
Thanks for the offer to help, Holger! I will take a look at dpclipse and get
back to you soon with some ideas about how we can work together on this.
-- John Graham
john.graham@sybase.com
Eclipse DTP
"Holger Dehnhardt" <dehnhardt@snafu.de> wrote in message
news:d0pj0o$mha$1@www.eclipse.org...
>a lot of the features, which are mentioned in the proposal are similar to
> the ones, I _planned_ to integrate into my 'DBClipse' plugin(s). But as
> I'm
> only able to do this kind of work at evening, I didn't get too far until
> now. See (http://sourceforge.net/projects/dbclipse).
> I would like to offer my help in planning and coding, and maybe some
> ideas/code from my project is usable.
> Holger
Re: Similar Features... [message #115 is a reply to message #90] |
Fri, 18 March 2005 08:59 |
Holger Dehnhardt Messages: 4 Registered: July 2009 |
Junior Member |
Some more Words about why I started programming these plugins:
- Database Development
I currently work on 2 projects, where all business-logic is implemented with
stored procedures. We use Sybase databases, one ASA for a small department
and one ASE for the rest of our enterprise.
Until now I use text-files to code the procedures, because I did not find
any database-tool, which worked better for me than TextPad (Win) or Kate
(Linux) - both with 'tuned' syntax files.
What I always missed is code-completion, support for CVS etc., a
posssibility to synchronize the scripts with the database, a graphical
debugger, a possibility to compile SPs with all it's dependencies and the
possibility to show the output of query-plans at the right position in a
batch.
In the last month there came up some tools, which support code completion
(DBVisualizer, Datastudio ...) but mostly the support is very basic: No
variables, no objects from other databases, no syntax-dependent completion
and so on.
- Database Administration
Here the situation is a lot better, usually the tools from the db-vendors do
a good job - but:
If you want one tool for different vendors, the functionality often is very
limited.
I've never seen a tool which has the possibility, to show an overview over
all running databases with hints if something is wrong (running out of
disk-space, to much connections...)
As I said before - nothing of the above mentioned features is implemented in
dbclipse, the last thing I was working on was a XML-configurable SQL-Parser
to support different SQL-dialects with one editor. (I fear, this alone will
be a several years project for one programmer...)
Thanks for reading!
Holger
> get back to you soon with some ideas about how we can work together on
> this.
> -- John Graham
> Eclipse DTP
>> I'm
>> Holger
Re: Similar Features... [message #564282 is a reply to message #90] |
Junior Member |
batch.
and so on.
a good job - but:
limited.
Thanks for reading!
Holger
> this.
> -- John Graham
> Eclipse DTP
>> I'm
>> Holger
Current Time: Sat Oct 19 12:00:04 GMT 2024
Powered by FUDForum. Page generated in 0.03794 seconds
