| Compiler errors are not complete [message #90586] |
Wed, 24 December 2003 05:54  |
Originally posted by: toomy.bluewin.ch
Hi all,
I have anoter question regarding the compiler errors. It seems that they=
are not shown complete in the Tasks window.
If I have a look to the C-Bulid window, the complete description is give=
n. =
Is this the intent?
And second, does anybody know a good ressource where I can read about th=
e =
compiler errors?
Thanks markus
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
| Re: Compiler errors are not complete [message #90733 is a reply to message #90586] |
Mon, 29 December 2003 05:27  |
Markus Ruettimann wrote:
> Hi all,
> given. Is this the intent?
> the compiler errors?
> Thanks markus
When using GCC toolchain, you need to add to each compile/link line the
following (either in Makefile, add this to CFLAGS/CXXFLAGS/LDFLAGS, or
when using managed builds, add this in each configuration to the
misc-sections):
-fmessage-length=0
This will keep the compiler and linker to break lines at a default
value, which in fact, shortens the task/problem report entries.
FUDForum. Page generated in 0.04544 seconds
