Home » Language IDEs » C / C++ IDE (CDT) » Managed project cannot find linked source
Managed project cannot find linked source [message #90450] Mon, 22 December 2003 10:55 Go to next message
Originally posted by: dslice.wfubmc.edu
I am trying to set up a managed project using folders linked to an
existing source tree. The resulting makefiles, however, do not appear to
be able to find the source files in the linked directory. I get the error:
** No rule to make target 'src/main.o, need by 'singlesrc'. Stop.
If I put the source file in the directory created by Eclipse, it compiles
just fine. The makefile just can't find it in the linked directory.
I have found no (recognizable) discussion of this problem in the FAQs or
newsgroup.
How can I get eclipse, the make file, or whatever to find the sources?
TIA and Happy Holidays, dslice
Directories:
Eclipse
$HOME/workspace
/singlesrc
/Release: makefile
/src (linked to singlesrc -see below): subdir.dep and subdir.mk
Source
/home/temp/remotesrctest/singlesrc: main.cpp (simple helloworld app)
Makefile:
ROOT := ..
RM := rm -rf
# Each subdirectory must contribute its source files here
C_SRCS :=
CC_SRCS :=
CXX_SRCS :=
CAPC_SRCS :=
CPP_SRCS :=
LIBS :=
USER_OBJS :=
OBJS = $(C_SRCS:$(ROOT)/%.c=%.o) $(CC_SRCS:$(ROOT)/%.cc=%.o)
$(CXX_SRCS:$(ROOT)/%.cxx=%.o) $(CAPC_SRCS:$(ROOT)/%.C=%.o)
$(CPP_SRCS:$(ROOT)/%.cpp=%.o)
# Every subdirectory with source files must be described here
SUBDIRS := \
src \
# Include the makefiles for each source subdirectory
-include ${patsubst %, %/subdir.mk, $(SUBDIRS)}
all: singlesrc
singlesrc: $(OBJS)
g++ -o $@ $(OBJS) $(USER_OBJS) $(LIBS)
clean:
-$(RM) $(OBJS) singlesrc
PHONY: all clean deps
# Include automatically-generated dependency list:
-include ${patsubst %, %/subdir.dep, $(SUBDIRS)}
subdir.dep:
# Automatically-generated dependency list:
subdir.mk:
C_SRCS += \
${addprefix $(ROOT)/src/,\
CC_SRCS += \
CXX_SRCS += \
CAPC_SRCS += \
CPP_SRCS += \
main.cpp \
# Each subdirectory must supply rules for building sources it contributes
src/%.o: $(ROOT)/src/%.cpp
g++ -O3 -Wall -c -o $@ $<
Other
Redhat Linux 8.0 + updates
Eclipse Platform V.2.1.2
CDT 1.20
Re: Managed project cannot find linked source [message #90542 is a reply to message #90450] Tue, 23 December 2003 13:53 Go to previous messageGo to next message
Hi Dennis -
What I think you want to do is create a link from your external source
directory
into the project's root directory ("singlesrc") in your workspace:
ln -s /home/temp/remotesrctest/singlesrc $HOME/workspace/singlesrc/src
It looks like your linked dir is instead in the Release directory, which is
not searched by
Managed Make for new source files.
(BTW, what you're doing is clever, but not the original intention of the
feature,
and I was pleasantly surprised to see it work. Symbolic links are not
The Eclipse Way because they can lead to one source file appearing more than
once in your Projects navigator, which is an aggravating limitation.
Anyhow,
what you want to do should still work, so have fun.)
What this does is allow Managed Make to find all the source files within the
project, including your linked directory, and create its own Makefile and
compiled objects in the Release (or Debug) directories.
What this arrangement does *not* do is:
- it does not use your existing Makefile (Managed Make produces its own)
- it does not put your compiled object files into your external source
directory
To get around that second limitation, you could create your new Managed
Make project "in-place", that is, in the same place as your existing source
code.
In the New Project Wizard, de-select "Use default location" and navigate to
/home/temp/remotesrctest/singlesrc/. Your old Makefile will still get
ignored
(but not deleted), and your object files will go into a Release or Debug
subdirectory beneath your project's directory.
- Brent
"Dennis E. Slice" <dslice@wfubmc.edu> wrote in message
news:bs7464$pco$1@eclipse.org...
> newsgroup.
> Directories:
> Eclipse
> $HOME/workspace
> /singlesrc
> /Release: makefile
subdir.mk
> Source
> Makefile:
> ROOT := ..
> RM := rm -rf
> C_SRCS :=
> CC_SRCS :=
> CXX_SRCS :=
> CAPC_SRCS :=
> CPP_SRCS :=
> LIBS :=
> USER_OBJS :=
> SUBDIRS := \
> src \
> all: singlesrc
> singlesrc: $(OBJS)
> clean:
> subdir.dep:
> subdir.mk:
> C_SRCS += \
> CC_SRCS += \
> CXX_SRCS += \
> CAPC_SRCS += \
> CPP_SRCS += \
> main.cpp \
> Other
> CDT 1.20
Re: Managed project cannot find linked source [message #90622 is a reply to message #90542] Wed, 24 December 2003 14:19 Go to previous message
Brent,
Thanks so much for your helpful and detailed response.
The code that I am using is my own that has been around for a number of
years. I have worked with it via at least four IDEs (Borland, IBM,
Microsoft, Codewarrior) and on multiple platforms (Linux, Windows, Mac (9
and 10.x), Solaris, SGI). I like keeping this code safe and free of
various IDE "droppings".
I tried manually putting a link in the Eclipse directory, and sure enough,
it worked. The managed project was 99% there - all it needed to do was
make the link itself, but I guessed that might be a problem for different
platforms.
I checked and sure enough, the project link doesn't show up when the
directory (with absolute-path links) is Samba-mounted under Windows, but
much to my delight, it does show up if the link uses relative paths. I
haven't checked to see if the Windows version of Eclipse would actually
use it, but I am guessing it will. I don't mind giving Eclipse its own
subdirectory in my source tree for projects as long as I can't
inadvertantly delete the source files from Eclipse.
So, I think I am off and running. Now if I can just find a simple JNI
example and some instructions for how to debug both sides of JNI from
eclipse - seemlessly or not.
Brent Nicolle wrote:
> Hi Dennis -
> directory
> not searched by
> feature,
> Anyhow,
> directory
> code.
> ignored
> Cheers,
> - Brent
> > newsgroup.
> > Directories:
> > Eclipse
> > $HOME/workspace
> > /singlesrc
> > /Release: makefile
> subdir.mk
> > Source
> > Makefile:
> > ROOT := ..
> > RM := rm -rf
> > C_SRCS :=
> > CC_SRCS :=
> > CXX_SRCS :=
> > CAPC_SRCS :=
> > CPP_SRCS :=
> > LIBS :=
> > USER_OBJS :=
> > SUBDIRS :=
> > src
> > all: singlesrc
> > singlesrc: $(OBJS)
> > clean:
> > subdir.dep:
> > subdir.mk:
> > C_SRCS +=
> > CC_SRCS +=
> > CXX_SRCS +=
> > CAPC_SRCS +=
> > CPP_SRCS +=
> > main.cpp
> > Other
> > CDT 1.20
Previous Topic:Using a network drive?
Next Topic:Newbie, how to install CDT plugin. Eclipse version 2.1.2
Current Time: Mon Oct 27 01:08:12 EDT 2025
Powered by FUDForum. Page generated in 0.04309 seconds
