Home » Archived » Test and Performance Tools Platform (TPTP) » Profile launch fails: can't resolve data collectors
Profile launch fails: can't resolve data collectors [message #90171] Wed, 13 December 2006 17:33 Go to next message
Originally posted by: clark.updike.jhuapl.edu
!SESSION 2006-12-13 09:38:10.683
eclipse.buildId=M20060921-0945
When I try to launch a profile, I get a failure. The log file output is
below. Another user reported the same thing here
< http://dev.eclipse.org/newslists/news.eclipse.tptp/msg03186. html> but
never got any response.
TIA, Clark
java.version=1.5.0_02
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.hyades.trace.ui 4 0 2006-12-13 09:39:07.996
!MESSAGE An error occurred while attempting to resolve the data collectors
selected
!STACK 1
org.eclipse.core.runtime.CoreException: An error occurred while attempting
to resolve the data collectors selected
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:120)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.createCoreException(LauncherUtility.java:128)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:152)
at java.lang.Thread.run(Thread.java:595)
!SUBENTRY 1 org.eclipse.hyades.trace.ui 4 0 2006-12-13 09:39:07.996
selected
Re: Profile launch fails: can't resolve data collectors [message #90236 is a reply to message #90171] Wed, 13 December 2006 22:52 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
You need to specify what needs to be monitored before you can profile your
application. Follow the steps below:
- Open the profile launch configuration (Select 'Run' > 'Profile...' from
the menu OR use the profile drop down toolbar and select 'Profile...')
- Switch to the 'Monitor' tab
- Select one or more of the available analysis types under "Java Profiling
(...)". For example, "Execution Time Analysis"
This appears to be a usability issue if reported by multiple users. I have
opened the following defect for it to be addressed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=167976
Ali Mehregani
"Clark" <clark.updike@jhuapl.edu> wrote in message
news:49c55d54bb686e569478f7be8e3043d2$1@www.eclipse.org...
> !SESSION 2006-12-13
> 09:38:10.683 -----------------------------------------------
> TIA, Clark
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> selected
> !STACK 1
> at
> at
> at
> selected
Re: Profile launch fails: can't resolve data collectors [message #90267 is a reply to message #90236] Thu, 14 December 2006 14:11 Go to previous message
Thanks for filing that. Turns out that something was wrong with my
installation and I wasn't ever getting the monitor tab in the launch
dialog (or any tabs for that matter). I had installed tptp via update and
something must have gone wrong. I got the full eclipse bundle and the
launch dialog now works correctly. I'm still struggling to get it to run
the profile with the graphical execution flow--guess I'll have to
breakdown and RTFM.
P.S Here's the exception I get running tptp installed via the update
manager (when the tabs don't show up):
!ENTRY org.eclipse.jface 4 2 2006-12-14 09:04:50.919
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/tptp/trace/ui/internal/launcher/application/Filt erExtendedConfigurationPage
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TIE xtendedConfiguration. <init>(TIExtendedConfiguration.java:26)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.tptp.trace.ui.internal.launcher.core.Configurati onLoader.constructInstance(ConfigurationLoader.java:68)
org.eclipse.tptp.trace.ui.internal.launcher.core.Configurati onManager.initialize(ConfigurationManager.java:66)
org.eclipse.tptp.trace.ui.internal.launcher.core.Configurati onManager. <init>(ConfigurationManager.java:40)
org.eclipse.tptp.trace.ui.internal.launcher.core.Configurati onManager.getInstance(ConfigurationManager.java:86)
org.eclipse.tptp.trace.ui.internal.launcher.core.AnalysisTyp e.constructInstance(AnalysisType.java:66)
org.eclipse.tptp.trace.ui.internal.launcher.core.AnalysisTyp eManager.initialize(AnalysisTypeManager.java:43)
org.eclipse.tptp.trace.ui.internal.launcher.core.AnalysisTyp eManager. <init>(AnalysisTypeManager.java:32)
org.eclipse.tptp.trace.ui.internal.launcher.core.AnalysisTyp eManager.getInstance(AnalysisTypeManager.java:51)
org.eclipse.hyades.trace.ui.internal.launcher.ProfilingSetsM anager.initializeProfilingTypes(ProfilingSetsManager.java:23 5)
org.eclipse.hyades.trace.ui.internal.launcher.ProfilingSetsM anager.initialize(ProfilingSetsManager.java:117)
org.eclipse.hyades.trace.ui.internal.launcher.ProfilingSetsM anager.getDefaultSet(ProfilingSetsManager.java:594)
org.eclipse.hyades.trace.ui.launcher.ProfilingSetsManagerCop y.initializeProfilingSets(ProfilingSetsManagerCopy.java:181)
org.eclipse.hyades.trace.ui.internal.launcher.ProfilingSetsM anager.initialize(ProfilingSetsManager.java:118)
org.eclipse.hyades.trace.ui.launcher.ProfilingSetsManagerCop y. <init>(ProfilingSetsManagerCopy.java:51)
org.eclipse.hyades.trace.ui.internal.core.TraceProfileUI.get ProfilingSetWC(TraceProfileUI.java:964)
org.eclipse.hyades.trace.ui.internal.core.TraceProfileUI.cre ateDataCollectorTree(TraceProfileUI.java:277)
org.eclipse.hyades.trace.ui.internal.core.TraceProfileUI.cre ateFlatControl(TraceProfileUI.java:246)
org.eclipse.hyades.trace.ui.internal.core.TraceProfileUI.cre ateControl(TraceProfileUI.java:207)
org.eclipse.hyades.trace.ui.internal.launcher.ProfileTab.cre ateControl(ProfileTab.java:73)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.showTabsFor(LaunchConfigurationTabG roupViewer.java:757)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.showInstanceTabsFor(LaunchConfigura tionTabGroupViewer.java:697)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:632)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$6.run(LaunchConfigurationTabGroupVi ewer.java:548)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:565)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:529)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:928)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$4.selectionChanged(LaunchConfigurationsDia log.java:547)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:839)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:837)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1143)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1163)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:230)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 404)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:1086)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 3)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:387)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:329)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Previous Topic:org.xml.sax.SAXParseException when trying to profile a BIRT application using TPTP.
Next Topic:TIme-out occurred while attempting to launch the process
Current Time: Thu Dec 26 22:43:16 GMT 2024
Powered by FUDForum. Page generated in 0.03395 seconds
