Home » Archived » BIRT » Globals
Globals [message #90105] Fri, 11 November 2005 11:53 Go to next message
mr. burns is currently offline mr. burnsFriend
I thought that vars as report, design, params, etc. are global.
So they should be accessible from any event / part of code or not?
I tried also in the beforeOpen event to access report, config, params which
one can choose from the expression builder:
BIRT JavaScript Objects-->GlobalBIRT
But I get the same error message as with the previously posted params[]
problem:
...."report" is not defined
...."design" is not defined
...."params" is not defined
Even if I try captal letter Report, Design, Params, - no way!
So are the globals not global? How to access them? From which event?
Thanks for any help!
Re: Globals [message #91589 is a reply to message #90105] Wed, 16 November 2005 15:40 Go to previous messageGo to next message
is nobody able to help me?
Re: Globals [message #102382 is a reply to message #90105] Mon, 26 December 2005 08:10 Go to previous messageGo to next message
Wang Qiangsheng is currently offline Wang QiangshengFriend
Member
We provide new structure to support those objects. Please try with the
coming final build. It should include those object if every thing is ok.
Qiangsheng Wang
"Mr. Burns" <Mr._Burns@web.de> д
Re: Globals [message #103069 is a reply to message #102382] Fri, 30 December 2005 14:39 Go to previous message
Ok,
thanks, will try that!
Previous Topic:report params & filtering.... and using report parameters in data set filter
Next Topic:Happy new year!
Current Time: Wed Feb 05 14:13:29 GMT 2025
Powered by FUDForum. Page generated in 0.04493 seconds
