Re: Web Service wizard [message #90865 is a reply to message #90760] |
Thu, 07 April 2005 22:46 |
Originally posted by: lompafb.lompa.it
hallo,
i encountered the same problem: i created the dynamic web prject by myself
following following the instructiond i found in the "bottom up web service
tutorial". i installed tomcat before running the service (my version is
5.5.7), but i didn't start it. i also installed the server following the
instrucions in the same document.
in the "server" menu item, in project properties, the "target runtime"
value is "apache tomcat v5.0" and in the default server list box only the
items "none" and "tomcat v5.0 server @ localhost" are present. I cannot
find a way to configure this default server.
if i try to change the target runtime to "Apache tomcat v5.5" (the only
other available menu) the web service wizard tells me it cannot start the
server
thanx in advance, too
Michele Lombardi
FUDForum. Page generated in 0.03793 seconds
