Preferences won't save [message #89994] |
Thu, 28 August 2003 08:37  |
Originally posted by: dcorbin.imperitek.com
I'm was running I20030730, and "something happened". I ended up wiping
my workspace/.metadata directory. I can no longer change and save
certain preferences (Java/Compiler/Ignore Unused imports is one of
them). Changing this and pressing OK does not result in a build, and
when I return to the preferences dialog, it's set to the default. Apply
also does nothing.
I imported an "old" preferences export, but I'm not sure if that is
required to cause this problem. I've also tried with the I20030226 ot
no avail.
Suggestions? (other than "file a bug", which I will do, if it's not
something I've just got screwed up locally...)
David
Re: Preferences won't save [message #91534 is a reply to message #91118] |
Tue, 02 September 2003 09:52  |
Martin Aeschlimann wrote:
> Is this on linux? have a look at bug 41425 if this is what you're seeing.
>> wiping my workspace/.metadata directory. I can no longer change and
>> save certain preferences (Java/Compiler/Ignore Unused imports is one
>> of them). Changing this and pressing OK does not result in a build,
>> and when I return to the preferences dialog, it's set to the default.
>> Apply also does nothing.
>> ot no avail.
>> David
Yep.
FUDForum. Page generated in 0.03277 seconds
