Home » Newcomers » Newcomers » Can eclipse create a .jar file?
Can eclipse create a .jar file? [message #89873] Thu, 28 July 2005 02:02 Go to next message
Originally posted by: seanmc42.hotmail.com
I have a simple .class file - a Java app.
Can Eclipse package this into a .jar file
for me - and also create the manifest file
so that I can simply double-click on the
resulting .jar file in windows to run it?
Thanks!
Re: Can eclipse create a .jar file? [message #89901 is a reply to message #89873] Thu, 28 July 2005 02:47 Go to previous messageGo to next message
> Thanks!
You can do this by using the File \ export menu option.
In the Eclipse Help do a search for 'export manifest file'.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Can eclipse create a .jar file? [message #90100 is a reply to message #89873] Thu, 28 July 2005 10:45 Go to previous messageGo to next message
"exquisitus" <seanmc42@hotmail.com> wrote in message
news:dc9sep$sqe$1@news.eclipse.org...
Yes, it can I wrote a small article on that :
http://eclipse.techforge.com/index.php/articles/150
In some cases you want the help of FatJar to make your Jar executable.
Re: Can eclipse create a .jar file? [message #155901 is a reply to message #89901] Wed, 07 June 2006 10:11 Go to previous message
Originally posted by: banslow.us.ibm.com
I have a similar problem, the project (should) produce several jar files,
which are used by other parts of the project, and other projects.
Using "Export" is a somewhat manual process, I have to edit directories,
what to include, jar file name etc. for each file I want to produce.
Is there no way I can get the jar file to be built "automagically"? I have
other IDE's that can do this.
I have Eclipse 3.1.2 installed.
Bryan.
"IchBin" <weconsul@ptd.net> wrote in message
news:dc9v1j$vac$1@news.eclipse.org...
>> Thanks!
Previous Topic:Eclipse don't getting started
Next Topic:cannot drag a file
Current Time: Fri Nov 07 21:37:19 EST 2025
Powered by FUDForum. Page generated in 0.10617 seconds
