Can eclipse create a .jar file? [message #89873] |
Thu, 28 July 2005 06:02 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: seanmc42.hotmail.com
I have a simple .class file - a Java app.
Can Eclipse package this into a .jar file
for me - and also create the manifest file
so that I can simply double-click on the
resulting .jar file in windows to run it?
Thanks!
Re: Can eclipse create a .jar file? [message #89901 is a reply to message #89873] |
Thu, 28 July 2005 06:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Thanks!
You can do this by using the File \ export menu option.
In the Eclipse Help do a search for 'export manifest file'.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Can eclipse create a .jar file? [message #155901 is a reply to message #89901] |
Wed, 07 June 2006 14:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: banslow.us.ibm.com
I have a similar problem, the project (should) produce several jar files,
which are used by other parts of the project, and other projects.
Using "Export" is a somewhat manual process, I have to edit directories,
what to include, jar file name etc. for each file I want to produce.
Is there no way I can get the jar file to be built "automagically"? I have
other IDE's that can do this.
I have Eclipse 3.1.2 installed.
Bryan.
"IchBin" <weconsul@ptd.net> wrote in message
news:dc9v1j$vac$1@news.eclipse.org...
>> Thanks!
FUDForum. Page generated in 0.08079 seconds
