Home » Eclipse Projects » Remote Application Platform (RAP) » Selected ViewPart Tab Color
Selected ViewPart Tab Color [message #89698] Fri, 23 May 2008 13:09 Go to next message
how do change the Tab Color of select ViewPart/EditorPart?
Is it also possible to not make it look so anemic?
Markus
Re: Selected ViewPart Tab Color [message #89806 is a reply to message #89698] Sun, 25 May 2008 14:18 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Markus,
you could provide your own WorkbenchTheme via org.eclipse.ui.themes
the extension point.
In addition, these colors should also be configurable via
preferences, but as I am working offline and can't recall the API to
use, you would need to search around a bit.
A third approach would be to use RWT theming to change the colors of
the CTabFolder. This, of course, would also affect occurences of
CTabFolder outside the workbench parts.
Rüdiger
Markus Krüger wrote:
> Markus
Re: Selected ViewPart Tab Color [message #89861 is a reply to message #89806] Mon, 26 May 2008 03:16 Go to previous messageGo to next message
Hi R
Re: Selected ViewPart Tab Color [message #89896 is a reply to message #89861] Mon, 26 May 2008 04:31 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Markus,
> Hi Rüdiger,
> I use a RAP theme (css) and tried to set TabItem and CTabItem background
> color, but it take no effect.
> Setting "Shell-Titlebar" does seem to take affect (although the color I used
> gets displayed anemic vin the selected view/editor part), but changing this
> will effect all shells titelbar. So is this a bug?
No. Using the RWT theming you can only set the foreground and background
of selected and unselected items in a CTabFolder. The CTabFolder is an
RWT widget and is not aware of selected parts in the workbench.
Moreover, the theme colors are overwritten by the workbench anyway. So
you have to provide your own *workbench* theme using the extension point
org.eclipse.ui.theme.
Setting the background of Shell-Titlebar changes the system color
SWT.COLOR_TITLE_BACKGROUND which the default workbench theme refers to.
Best regards, Ralf
> "Rüdiger Herrmann" <rherrmann@innoopract.com> schrieb im Newsbeitrag
> news:g1cohj$h2o$4@build.eclipse.org...
>> Markus,
>> you could provide your own WorkbenchTheme via org.eclipse.ui.themes the
>> extension point.
>> In addition, these colors should also be configurable via preferences, but
>> as I am working offline and can't recall the API to use, you would need to
>> A third approach would be to use RWT theming to change the colors of the
>> CTabFolder. This, of course, would also affect occurences of CTabFolder
>> Cheers,
>> Rüdiger
>>> Hi,
>>> Regards,
>>> Markus
Re: Selected ViewPart Tab Color [message #90475 is a reply to message #89896] Wed, 28 May 2008 05:22 Go to previous messageGo to next message
Originally posted by: mike.xmos.com
I'm finding that the first RAP session I open has pale blue ViewPart
tabs, then subsequent sessions have normal blue tabs until I restart the
server. Has anyone else seen this happen?
Ralf Sternberg wrote:
> Hi Markus,
>> Hi Rüdiger,
>> background color, but it take no effect.
>> I used gets displayed anemic vin the selected view/editor part), but
>> changing this will effect all shells titelbar. So is this a bug?
> Best regards, Ralf
>>> Markus,
>>> Cheers,
>>> Rüdiger
>>>> Hi,
>>>> Regards,
>>>> Markus
Re: Selected ViewPart Tab Color [message #90637 is a reply to message #90475] Wed, 28 May 2008 21:43 Go to previous messageGo to next message
Yes, same here. with RC1 (I'll switch to RC2 tomorrow).
Seems to affect the whole theming.
Patrick
Re: Selected ViewPart Tab Color [message #90759 is a reply to message #90637] Thu, 29 May 2008 05:57 Go to previous messageGo to next message
Hi Mike, Patrick,
>> the server. Has anyone else seen this happen?
Do you mean workbench theming or RWT theming?
Can you provide more details how to reproduce this? Do you use a custom
RWT theme (org.eclipse.rap.ui.themes)? A custom workbench theme
(org.eclipse.ui.themes)?
Ralf
Re: Selected ViewPart Tab Color [message #90774 is a reply to message #90759] Thu, 29 May 2008 06:04 Go to previous messageGo to next message
> Hi Mike, Patrick,
> Ralf
I'm still getting this with the latest version of RAP and I don't use
any theming at all.
Mike
Re: Selected ViewPart Tab Color [message #90791 is a reply to message #90774] Thu, 29 May 2008 07:23 Go to previous messageGo to next message
Hi Mike,
>> custom RWT theme (org.eclipse.rap.ui.themes)? A custom workbench theme
> any theming at all.
Unfortunately, I cannot reproduce this problem with the RAP Demo
application. Any idea in which respect your application differs from the
Demo or under which circumstances this problem occurs? Just a guess: do
you use the Preference store? Can you provide some code?
Ralf
Re: Selected ViewPart Tab Color [message #91484 is a reply to message #90475] Tue, 03 June 2008 09:37 Go to previous message
while smoke-testing 1.1 RC3, I was able to reproduce the behavior as
described in the previous posting.
I filed a bugzilla to gather further information and track progress
on this issue:
235331: Wrong workbench colors in very first session
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235331
Rüdiger
>> Hi Markus,
>>> Hi Rüdiger,
>> background of selected and unselected items in a CTabFolder. The
>> CTabFolder is an RWT widget and is not aware of selected parts in the
>> workbench. Moreover, the theme colors are overwritten by the workbench
>> anyway. So you have to provide your own *workbench* theme using the
>> extension point org.eclipse.ui.theme.
>> Best regards, Ralf
>>>> Markus,
>>>> Cheers,
>>>> Rüdiger
>>>>> Hi,
>>>>> Regards,
>>>>> Markus
Previous Topic:Problems using swt.virtual and a lazy content provider
Next Topic:Problem with FileDialog
Current Time: Sun Oct 26 22:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.04933 seconds
