Re: Command Save / Save Action not working ??? [message #89776 is a reply to message #89631] |
Sun, 25 May 2008 17:52 |
Originally posted by: rherrmann.innoopract.com
Markus,
I gave this a quick try, but ended up with the same results as you
did. Maybe you should ask this on the PlatformUI newgroup.
Rüdiger
Markus Krüger wrote:
> I added my whole menu through the extension point "org.eclipse.ui.menus".
> This way the Save action does not work correctly as it does not have a
> handler set. CloseAction and CloseAllAction works properly. I get the Save
> to work, if I call
> register( ActionFactory.SAVE.create( window ) );
> in my ActionBarAdvisor, but that's not a good solution, I think.
> Any suggestions, or am I missing something?
> Markus
FUDForum. Page generated in 0.03353 seconds
