[ Teneo ] USE_MAPPING_FILE minor enhancement [message #89043] |
Wed, 11 July 2007 14:29  |
Hi All,
I ran into some small trouble getting
teneoProps.setProperty(PersistenceOptions.USE_MAPPING_FILE, "true");
to work. I had a mapping file in the root directory and it looked like it
was working, but when I changed the mapping file, the changes wouldn't show
up.
It turns out that the code that looks for the mapping file looks for the
resource in ";hibernate.hbm.xml" which it doesn't find. It then just builds
its own hbm from the available code and seems like it worked even though it
actually didn't. I fixed it by adding code to StoreUtil.java like this:
//--- JJH support for userSpecifiedHBMFile
private static String userSpecifiedHBMFile;
public static String getSpecificMappingFile()
return userSpecifiedHBMFile;
public static void setSpecificMappingFile(String val)
userSpecifiedHBMFile=val;
//--- JJH
Then in StoreUtil.getFileList() I added:
//--- JJH: Want to specify a teneo generated mapping file that isn't
named hibernate.hbm.xml
if(null != getSpecificMappingFile()){
result.add(getSpecificMappingFile());
//--- JJH
return result.toArray(new String[result.size()]);
This should really go into Properties, but I didn't want to make property
names without your involvement since the documentation has to be updated and
what not. But the idea is helpful because I can specify exactly which hbm
file to use. (I have a different hbm for each project and I prefer to not
have them all named the same thing, even if they are in different projects)
If you give me a property name to use, I'll make this code nicer, put it
into a Property and submit it.
Thanks!
Jason Henriksen
Re: [ Teneo ] USE_MAPPING_FILE minor enhancement [message #89059 is a reply to message #89043] |
Wed, 11 July 2007 14:37  |
Hi Jason,
I think this propertyname would work:
public static final String HIBERNATe_MAPPING_FILE_NAME = MAPPING_PREFIX +
"hibernate_mapping_file_name";
It would be great if you can submit a patch for this, thanks!
gr. Martin
Jason Henriksen wrote:
> Hi All,
> up.
> //--- JJH
> //--- JJH
> Thanks!
> Jason Henriksen
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [ Teneo ] USE_MAPPING_FILE minor enhancement [message #608701 is a reply to message #89043] |
Hi Jason,
gr. Martin
> Hi All,
> up.
> //--- JJH
> //--- JJH
> Thanks!
> Jason Henriksen
The Netherlands
FUDForum. Page generated in 0.02655 seconds
