Home » Eclipse Projects » Equinox » NoClassDefFound issue
NoClassDefFound issue [message #89032] Thu, 31 May 2007 09:23 Go to next message
Originally posted by: karl.reti.bridgeforward.net
I have an odd issue that only started occurring on M7 and has continued to
RC2. I have a bundle that exposes a service that initializes an MBean
Server.
Under M6 and previous builds this works perfectly fine, on M7 and RC2 I
get the following error
Nested Exception:
java.lang.NoClassDefFoundError: javax/management/MBeanServer
com.bf.service.management.jmx.JMXService.initialize(JMXServi ce.java:33)
at com.bf.service.management.jmx.Activator.start(Activator.java :25)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
etc etc
If I take the same code, and run under Equinox M6 its fine, if I run under
Equinox M7 it breaks. I have tried re-compiling under both versions, I
have double checked that there are no differences in the classpath,
config.ini etc and its all the same..
Anyone any ideas ??
Karl
Re: NoClassDefFound issue [message #89049 is a reply to message #89032] Thu, 31 May 2007 12:21 Go to previous messageGo to next message
Just some additional information on the previous post..
Under M6 I get the following..
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070321
1 ACTIVE org.eclipse.equinox.log_1.0.100.v20070226
2 ACTIVE org.eclipse.osgi.services_3.1.100.v20060918
3 ACTIVE com.bf.service.management.jmx_1.0.0
Very bare bones JMX Management plugin
Under M7 and RC2..
id State Bundle
0 ACTIVE org.eclipse.osgi_3.3.0.v20070523
3 RESOLVED com.bf.service.management.jmx_1.0.0
The only change has been in org.eclipse.osgi.
Bundle 3 generates the NoClassDefFound error..
Karl
Re: NoClassDefFound issue [message #89088 is a reply to message #89049] Thu, 31 May 2007 13:41 Go to previous message
This is being tracked here -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190275
"Karl Reti" <karl.reti@bridgeforward.net> wrote in message
news:dea64374a7c96143d6fd0e64d63fce05$1@www.eclipse.org...
> id State Bundle
> Under M7 and RC2..
> id State Bundle
> Karl
Previous Topic:Equinox running cocoon on the server (WEB-INF confusion)
Next Topic:Equinox in clustered server env
Current Time: Mon Nov 03 14:59:20 EST 2025
Powered by FUDForum. Page generated in 0.03138 seconds
