Home » Modeling » GMF (Graphical Modeling Framework) » A question about write transactions
A question about write transactions [message #88846] |
Tue, 02 January 2007 18:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: awm_abu.yahoo.com
I am trying to add EditParts to my model programmatically.
I had a look at the documentation but I can't seem to see how to create a
write transaction.
I get the exception which you can see below
Sorry if this is a simple question but this is proving very frustrating for
me at the moment
Any help greatly appreciated.
java.lang.IllegalStateException: Cannot modify resource set without a write
transaction
Re: A question about write transactions [message #88923 is a reply to message #88846] |
Tue, 02 January 2007 21:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: vcciubot.uwaterloo.ca
How do you plan to add the EditParts? By creating views or model elements?
To write to your model you must use an AbstractTransactionalCommand and
execute it on the operation history. If returned from an editPolicy wrap
it around an ICommandProxy.
Explore the type hierarchy of AbstractTransactionalCommand to see example
commands.
Many edit policies contain examples: SemanticEditPolicy,
CreationEditPolicy etc.
hope this helps,
-Vlad
On Tue, 02 Jan 2007 18:49:14 +0000, Alan wrote:
> Hello,
> write transaction.
> me at the moment
> Thanks:
> transaction
Re: A question about write transactions [message #89042 is a reply to message #88923] |
Wed, 03 January 2007 10:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for the reply.
I created a subclass of AbstractTransactionalCommand and used that to create
my model elements
But I still got the same error. I am obviously missing something.
Perhaps if I tell you a bit more about what I am trying to do it might make
more sense.
My diagram contains a number of containers in a grid-like layout.
To start with I have, say, 3 rows and 5 columns. So that is 15 objects.
In my DiagramEditorUtil class in the createInitialRoot method I create these
15 objects in my model.
This works fine...the objects appear on the diagram on startup.
Now later the user decides to add another row.
This means I need another 5 objects in my model.
When I try to add objects to the model however I get the no write
transaction error.
Not sure if this extra info helps but maybe.
Anyway any pointers you could give me would be great.
"Vlad Ciubotariu" <vcciubot@uwaterloo.ca> wrote in message
news:pan.2007.01.02.21.02.10.619112@uwaterloo.ca...
> commands.
> hope this helps,
> -Vlad
>> Hello,
>> write transaction.
>> for
>> me at the moment
>> Thanks:
>> write
>> transaction
Re: A question about write transactions [message #89214 is a reply to message #89042] |
Wed, 03 January 2007 16:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Where exactly are you trying to add the 5 new objects to your model? And,
is the row represented in your model?
If so, one easy way is to extend the edit helper of the row model element
so that upon creation it is configured with 5 children.
In that edit helper override
* Gets the command to configure a new element of my kind. By default,
* returns <code>null</code>. Subclasses may override to provide their
* command.
* @param req
* the configure request
* @return the configure command
protected ICommand getConfigureCommand(ConfigureRequest req) {
return null;
Here's an example of how to do this:
* Returns a command that configures this block.
* <p>
* In subclasses override {@link BlockEditHelper#doConfiguration(EObject, IProgressMonitor)}
protected ICommand getConfigureCommand(final ConfigureRequest req) {
return new ConfigureElementCommand(req) {
protected CommandResult doExecuteWithResult(
IProgressMonitor monitor, IAdaptable info)
throws ExecutionException {
EObject element = req.getElementToConfigure();
doConfiguration(element, monitor);
return CommandResult.newOKCommandResult(element);
* Configures the block with a block interface.
* TODO: Could we add this directly to the ecore model?
* To configure the pipeline see {@link Bluenose2DiagramEditorUtil}.
protected void doConfiguration(EObject element, IProgressMonitor monitor) {
Block block = (Block) element;
B2CreationCommandUtil.createBlkInterface(block, monitor);
//testing the vhdlid
Pipeline pipe = (Pipeline) EMFCoreUtil.getContainer(block, Bluenose2Package.eINSTANCE.getPipeline());
int id = Bluenose2SemanticUtil.getAndIncrementId(pipe, IDTypes.VHDL_ID);
block.setVhdlId("" + id);
Finally, element creation inside a command should be done this way:
EMFCoreUtil.create(element, containment, eClass)
-Vlad
> my model elements
> more sense.
> transaction error.
>> commands.
>> hope this helps,
>> -Vlad
>>> Hello,
>>> write transaction.
>>> for
>>> me at the moment
>>> Thanks:
>>> write
>>> transaction
Re: A question about write transactions [message #89349 is a reply to message #89214] |
Thu, 04 January 2007 12:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No the row is not represented in my model.
In my model the Diagram itself contains the containers
The blocks then go in the containers
The containers are created programmatically.
I start with 15 (3 rows x 3 cols)
Then the user can change the row/column configuration which means adding
containers.
This is the problem I am currently dealing with.
As a row does not exist in model does this make the solution you proposed
below unsuitable ?
Any other thoughts ?
news:pan.2007.01.03.16.03.16.892127@uwaterloo.ca...
> * command.
> * @param req
> return null;
> * <p>
> IProgressMonitor)}
> -Vlad
>> create
>> my model elements
>> make
>> more sense.
>> these
>> transaction error.
>>> elements?
>>> example
>>> commands.
>>> hope this helps,
>>> -Vlad
>>>> Hello,
>>>> a
>>>> write transaction.
>>>> for
>>>> me at the moment
>>>> Thanks:
>>>> write
>>>> transaction
Re: A question about write transactions [message #89718 is a reply to message #89349] |
Fri, 05 January 2007 15:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
It should work the same way. As long you configure the newly created
containers or update the old ones.
You can send me some code to look at, no problem.
vlad
> containers.
> below unsuitable ?
>> * command.
>> * @param req
>> return null;
>> * <p>
>> IProgressMonitor)}
>> -Vlad
>>> create
>>> my model elements
>>> make
>>> more sense.
>>> these
>>> transaction error.
>>>> elements?
>>>> example
>>>> commands.
>>>> hope this helps,
>>>> -Vlad
>>>>> Hello,
>>>>> a
>>>>> write transaction.
>>>>> for
>>>>> me at the moment
>>>>> Thanks:
>>>>> write
>>>>> transaction
Current Time: Mon Jul 22 00:28:09 GMT 2024
Powered by FUDForum. Page generated in 0.04217 seconds
