Home » Language IDEs » C / C++ IDE (CDT) » Out of memory
Out of memory [message #88769] Mon, 08 December 2003 17:04 Go to next message
I'm on Linux with 1Gb of memory + 2Gb of swap. My Java console claims that
I'm running out of memory(java.lang.OutOfMemoryError).
- are there any options in Eclipse that I can set (e.g., for the Java VM?)
- is there a way to tell Eclipse to ignore (not keep in inventory) some
files? My include directory is a bunch of soft links to each source
directory where the *.cc and *.h are mixed. I fear that it doubles the
number of inventoried files. I saw options for CVS but I think I need
something stronger. My "bin" directory is also large as well as "lib"
directory.
Any hints are welcomed.
Cheers, Pierre
Re: Out of memory [message #88784 is a reply to message #88769] Mon, 08 December 2003 20:51 Go to previous message
I found the following from the main Eclipse group:
Memory can be controlled by adding: -vmargs -Xmx512M
Seems to help. Cheers, Pierre
> directory.
> Cheers, Pierre
Previous Topic:Eclipse 3.0M5 GTK/CDT 2.0M5 debug problem
Next Topic:external debugger
Current Time: Wed Apr 16 07:57:32 EDT 2025
Powered by FUDForum. Page generated in 0.05919 seconds
