Home » Archived » BIRT » Problem with Binding Report Parameters to DateSet Parameters
Problem with Binding Report Parameters to DateSet Parameters [message #88575] Mon, 07 November 2005 17:39 Go to next message
Originally posted by: pcasey.earthlink.net
I have a dataset parameter named startDateDS:
Type = Date Time
Direction = Input
Default Value = '11/01/05'
When I preview the query with this parameter, it works fine.
I have a report parameter named startDate:
Type = Date Time
Format = Unfomratted
Default Value = 11/01/2005
I have bound my report parameter to my dataset parameter:
Parameter=startDateDS
Data Type=Date Time
Value=params["startDate"]
When I try to preview the report though I get errors, specifically:
There are errors on the report page:
- There are error(s) in Table:null
Error0 : data.engine.ConvertDataTypeError(1 time)detail: Cannot convert the
parameter value [Wed Dec 31 16:00:00 PST 1969] to type [class
java.util.Date]DateDate Please help, I'm pulling my hair out over
s. --- Pat
Re: Problem with Binding Report Parameters to DateSet Parameters [message #88861 is a reply to message #88575] Tue, 08 November 2005 14:22 Go to previous messageGo to next message
I tested this scenario, and I was able to preview my report. How did you
bind the data set parameter to the report parameter? Did you bind it through
the table that displays the data?
"Patrick Casey" <pcasey@earthlink.net> wrote in message
news:dkol3u$d79$1@news.eclipse.org...
> Type = Date Time
> Direction = Input
> Type = Date Time
> Data Type=Date Time
the
> s. --- Pat
Re: Problem with Binding Report Parameters to DateSet Parameters [message #88876 is a reply to message #88861] Tue, 08 November 2005 14:31 Go to previous messageGo to next message
Yep, I did it via the table.
I also found that if I define the Report Parameter as a String (not a
date/time) that it works, but if both the dataset and report parameters are
date/times, I get the error listed below.
--- Pat
"Diana Peh" <diana.peh@actuate.com> wrote in message
news:dkqts4$eas$1@news.eclipse.org...
> through
>> Type = Date Time
>> Direction = Input
>> Type = Date Time
>> Data Type=Date Time
> the
>> s. --- Pat
Re: Problem with Binding Report Parameters to DateSet Parameters [message #88891 is a reply to message #88876] Tue, 08 November 2005 14:56 Go to previous messageGo to next message
The data type might have been a problem with an earlier version of BIRT. In
the 2.0 Milestone 2 version, both the data set and report parameter can be
datetime type.
news:dkque8$f47$1@news.eclipse.org...
are
> --- Pat
> > through
> >> Type = Date Time
> >> Direction = Input
> >> Type = Date Time
> >> Data Type=Date Time
> > the
> >> s. --- Pat
Re: Problem with Binding Report Parameters to DateSet Parameters [message #88906 is a reply to message #88891] Tue, 08 November 2005 15:05 Go to previous message
I'm still on 1.0.1 on the theory that it's the more stable release. As I
work more with Birt though I'm starting ot think I might be better off with
the 2.0 milestones. Can anyone comment on that e.g. is 2.0 M2 more
stable/less buggy than 1.0.1?
--- Pat
news:dkqvs4$h5b$1@news.eclipse.org...
> In
> datetime type.
> are
>> --- Pat
<snip>
Previous Topic:Problems understanding monthly groupings
Next Topic:Text/cell alignment
Current Time: Tue Sep 16 13:44:36 EDT 2025
Powered by FUDForum. Page generated in 0.03885 seconds
