Home » Archived » Test and Performance Tools Platform (TPTP) » Problems getting AGR to work wth RCP
Problems getting AGR to work wth RCP [message #88473] Wed, 22 November 2006 12:18 Go to next message
I am having no luck attempting to record an RCP using the Automated GUI
Test application.
One suggestion that was made was to install the AGR on top of my
application.
The following is an extract from another newsgroup article:
"To be able to install AGR on top of your application, you'll need the
following TPTP downloads:
1) Platform sub-project
2) Test sub-project
3) AGR plug-in
4) Eclipse Modeling Framework
Make sure that the version of TPTP you select is compatible with the
Eclipse
version that your application uses. For example, if your application runs
on Eclipse 3.2, then use TPTP 4.2."
How do I go about installing the AGR on top of my application. If I copy
the features and plug-ins to the respective directory under my application
it has no effect.
If I install my application on to of the AGR then I just had what was
originally installed under Eclipse.
Any ideas?
Re: Problems getting AGR to work wth RCP [message #88488 is a reply to message #88473] Wed, 22 November 2006 14:31 Go to previous message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006B36478525722E_=
Content-Type: text/plain; charset="US-ASCII"
AGR currently does not support RCP applications. Please see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159
Feel free to add yourself to the CC list. To increase the chances of this
enhacement getting implemented, make sure you vote for it.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">AGR currently does not support RCP applications.
&nbsp;Please see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159</font>
<br><font size=2 face="sans-serif">Feel free to add yourself to the CC
list. &nbsp;To increase the chances of this enhacement getting implemented,
make sure you vote for it.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 006B36478525722E_=--
Previous Topic:Starting Agent Controller on Linux failing
Next Topic:[Tests] Launching tests via the command line (posting on behalf of user)
Current Time: Sun Apr 27 01:57:40 EDT 2025
Powered by FUDForum. Page generated in 0.02039 seconds
