Re: [AGR] Disablement of test macros in suite editor's Behavior tab [message #89041 is a reply to message #88762] |
Wed, 29 November 2006 12:39 |
Barbara Rosi-Schwartz Messages: 448 Registered: July 2009 |
No, I cannot get it to work either with old or with newly recorded test
suites. Adn still I cannot understand what I am doing wrong... :-(
B.
Ali Mehregani wrote:
> If you can verify that the option works for newly created test suites and it
> doesn't function for pre-existing test suites, then it is a defect.
> "Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
> news:ek6b00$u42$1@utils.eclipse.org...
>> So does this mean that I cannot use the feature with pre existing test
>> suites? Or is it a bug that I should enter in Bugzilla?
>> Thanks,
>> B.
>>> I can't reproduce this problem with newly created test suites.
>>> I even tried disabling test invocations that belong to other test suites.
>>> message news:ek1pil$8rv$1@utils.eclipse.org...
>>>>> The disable/enable button is only applicable when the test suite is
>>>>> launched in standard mode. It seems to be working fine in TPTP4.2.1.
>>>>> Are you experiencing this with newly created test suites or existing
>>>>> test suites?
>>>>> message news:ejv4jl$q8f$1@utils.eclipse.org...
>>>>>> Hello everybody.
>>>>>> In the Behavior tab of a test suite I have a sequence of macros
>>>>>> listed. I want to exclude one temporarily from the sequence and
>>>>>> therefore I disable it using the Disable/Enable button to the right of
>>>>>> the list, but the macro is still being ran. Why is that? Am I
>>>>>> misunderstanding the purpose of the Disable/Enable button?
>>>>>> TIA
>>>>>> B.
>>>> Hi Ali.
>>>> Thanks for your reply.
>>>> Yes, I am launching the suite in standard mode, under TPTP4.2.1 and
>>>> Eclipse 3.2.1 and I have this problem with an existing test suite (I
>>>> have not yet tried with a new suite). The test case that I am disabling
>>>> does not belong to the same suite, but is defined elsewhere and invoked
>>>> in this suite.
>>>> Thanks,
>>>> B.
FUDForum. Page generated in 0.03489 seconds
