Home » Archived » BIRT » Acces to Data Set Parameters in Report Body
Acces to Data Set Parameters in Report Body [message #88012] Sun, 06 November 2005 22:29 Go to next message
Originally posted by: pcasey.earthlink.net
I have a report (purchases by date) that gets run from the web. The report
has a data set that takes two parameters startDate and endDate and then does
a query bounded by those markers. It works fine.
I want, however, to use those two parameters within the report e.g. print a
title that says:
'All Purchases between ' + startDate + ' and ' + endDate
The only problem is that startDate and endDate appear null during report
render :(. Is there a different javascript expression I should be using to
get at them? Is there a global DataSet.parameters.startDate or some such I
could use?
Alternately, how would you suggest working this out?
--- Pat
Re: Acces to Data Set Parameters in Report Body [message #88028 is a reply to message #88012] Sun, 06 November 2005 23:40 Go to previous messageGo to next message
Originally posted by: none.none.none
Hi Patrick,
If I understand you correctly, I think you want to do this:
'All Purchases between ' + params["startDate"] + ' and ' + params["endDate"]
"Patrick Casey" <pcasey@earthlink.net> wrote in message
news:dkmhnb$isp$1@news.eclipse.org...
> does a query bounded by those markers. It works fine.
> a title that says:
> could use?
> --- Pat
Re: Acces to Data Set Parameters in Report Body [message #88378 is a reply to message #88028] Mon, 07 November 2005 13:02 Go to previous message
I think that would work if I was using a report parameter, but I'm
trying to access a dataSet parameter. When I use the syntax you describe, I
get:
There are errors on the report page:
- There are error(s) in Data:null
Error0 : data.engine.JSScriptInvalid(2times)detail: Invalid Javascript
expression. Source: , line: 0, Expression:Script engine error: startDate not
found I tried using report parameters, but I could not, for the life of
me, get the data binder to bind a datatime report parameter (with default
value) to a datetime dataset parameter. So right nowI'm using only dataset
parameters. --- Pat"chris" <none@none.none> wrote in message
news:dkmlrn$mce$1@news.eclipse.org...
> Hi Patrick,
> params["endDate"]
>> report has a data set that takes two parameters startDate and endDate and
>> then does a query bounded by those markers. It works fine.
>> a title that says:
>> to get at them? Is there a global DataSet.parameters.startDate or some
>> such I could use?
>> --- Pat
Previous Topic:Integrating BIRT with Your Application
Next Topic:How obtain normal and bold font in same report
Current Time: Fri Oct 17 16:42:05 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
