Home » Language IDEs » ServerTools (WTP) » Axis error
Axis error [message #87968] Tue, 29 March 2005 05:09 Go to next message
Originally posted by: kthuno.gmail.com
When trying to make a web service from an existing class in a j2ee web
project I get this:
IWAB0489E Error when deploying Web service to Axis runtime
axis-admin failed with
{http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
Output in console (Tomcat):
2005-03-29 12:05:03 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Starting service Tomcat-Standalone
Apache Tomcat/4.1.31
2005-03-29 12:05:06 org.apache.struts.util.PropertyMessageResources <init>
INFO: Initializing, config='org.apache.struts.util.LocalStrings',
returnNull=true
INFO: Initializing, config='org.apache.struts.action.ActionResources',
returnNull=true
INFO: Initializing, config='org.apache.webapp.admin.ApplicationResources',
returnNull=true
2005-03-29 12:05:09 org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
2005-03-29 12:05:09 org.apache.jk.common.ChannelSocket init
INFO: JK2: ajp13 listening on /0.0.0.0:8009
2005-03-29 12:05:09 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/32
config=C:\jakarta-tomcat-4.1.31\conf\jk2.properties
- Unable to find config file. Creating new servlet engine config file:
/WEB-INF/server-config.wsdd
What to do???
TIA,
Kasper
Re: Axis error [message #88611 is a reply to message #87968] Tue, 29 March 2005 23:20 Go to previous messageGo to next message
Kasper,
This bug report appears to describe the problem you're experiencing.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88349
Please have a look, and append any comments you think may help. Thanks!
-seng
> project I get this:
> java.lang.NullPointerException
> returnNull=true
> returnNull=true
> INFO: Initializing,
> config='org.apache.webapp.admin.ApplicationResources', returnNull=true
> What to do???
> TIA,
> Kasper
Re: Axis error [message #88817 is a reply to message #88611] Wed, 30 March 2005 07:18 Go to previous messageGo to next message
Seng Phung-Lu wrote:
> Kasper,
> -seng
>> project I get this:
>> returnNull=true
>> returnNull=true
>> INFO: Initializing,
>> config=C:jakarta-tomcat-4.1.31confjk2.properties
>> What to do???
>> TIA,
>> Kasper
Thats the same problem as I have but unfortunately it has no solution, so
I guess all I can do is wait.
/Kasper
Re: Axis error [message #89687 is a reply to message #88817] Sat, 02 April 2005 06:54 Go to previous messageGo to next message
Hello all,
I'm having the same problem with the tutorial.
I installed the bundled eclipse-prereqs bundle (installed the required
jars manually) and a clean install of Tomcat 5.0.
If I can provide you with any more detail, please let me know how, and
I'll be glad to try and help,
thanks,
Ben
Re: Axis error [message #91186 is a reply to message #89687] Fri, 08 April 2005 19:51 Go to previous messageGo to next message
Originally posted by: akuma16.email.com
I'm having the same problem too. Looks like this will be a hard one to
pinpoint considering I'm running the exact same setup (versions and all) as
the tutorial
"Ben Dayan" <ben.dayan@gmail.com> wrote in message
news:2950960e6a25f0cdb82a1d9012173625$1@www.eclipse.org...
> Hello all,
> thanks,
> Ben
Re: Axis error [message #91309 is a reply to message #91186] Sun, 10 April 2005 15:58 Go to previous message
Originally posted by: lompafb.lompa.it
I had this problem too: i solved it downloading the RC3 release from the
axis web site
Previous Topic:IBM Web Tools for Eclipse - Licensing & support
Next Topic:Problems with the creation of EJB 2.1
Current Time: Fri Oct 31 00:27:11 EDT 2025
Powered by FUDForum. Page generated in 0.03127 seconds
