Re: ActiveBPEL Runtime Plug-in 0.4 Available for Download [message #8803 is a reply to message #7928] |
Fri, 27 July 2007 14:01 |
Originally posted by: carlos.grahl.senior.com.br
I've downloaded your activeBpel runtime plugin, unzip it on the Eclipse
plugins folder, but nothing happens.
When I open the servers runtime dialog, the ActiveBPEL option is not
available. I tried with Eclipse versions 3.2 and 3.3.
Did I miss something? Are there any more steps to be done?
Thanks in advance
Carlos Augusto Grahl
Re: ActiveBPEL Runtime Plug-in 0.4 Available for Download [message #8818 is a reply to message #8803] |
Fri, 27 July 2007 17:56 |
Some news...
I run the "Validate Plug-ins" on the "plugins" tab on the Run Dialog. The
plugin appears on the problems list, with the following error message:
"Missing constraint: Require-Bundle: org.wsdl4j; bundle-version="0.0.0""
That could help... I have WTP installed also on my Eclipse (3.3 version).
Any tips?
thank you
Re: ActiveBPEL Runtime Plug-in 0.4 Available for Download [message #9274 is a reply to message #9251] |
Wed, 01 August 2007 13:05 |
Hi!
Thank you for your reply.
I'm using the Europa released version of all plugins:
DTP: 1.5.0.20070621
EMF: 2.3.0.v200706262000
GEM: 1.0.100.v20070601-1400-7d-Et....
WTP: 2.0.0.v200706041905-7C-18...
Are you planning to open-source your plugin?
Thank you again,
Re: ActiveBPEL Runtime Plug-in 0.4 Available for Download [message #9319 is a reply to message #9296] |
Wed, 01 August 2007 14:14 |
Hi, Bruno!
Thank you for your quick reply.
I'll soon download and test this new version.
And yes, i'm interested in contribute to this plugin development. I'm
planning to use the activeBpel engine, and this plugin will be very, very
usefull :-)
How can I get the source? Should i wait for your CVS be ok?
Thank you
FUDForum. Page generated in 0.03397 seconds
