Home » Archived » DSDP » Run and Debug j2me as "installed JREs"
Run and Debug j2me as "installed JREs" [message #7899] Mon, 27 February 2006 01:27 Go to next message
keanu is currently offline keanuFriend
Member
I'd like to use IBM j9 VM, j2me CDC VM I have, as "Installed JREs" when I
develop eclipse application.
However the panel, "windows > preferences > java > installedJREs",
does not fit well with IBM j9 (CDC / FP 1.0).
I tried with "add" butten, only to fail.
I tried with "search" button, finding some directories.
However the directory found by "search" function is wrong directories.
steps
1) hit "search button" in the panel "Installed JREs"
2) select directory "C:\java\wsdd571\wsdd5.0\ive-2.2" which IBM j9 VMs are
under the directory.
3) Brings some awkward directories as "found".
I tried same funtions with Sun J2SE VM, and it works well.
How can I run and debug IBM j9, or other j2me VM available, explicitly
with the current eclipe 3.x?
Re: Run and Debug j2me as "installed JREs" [message #7933 is a reply to message #7899] Mon, 08 May 2006 19:49 Go to previous message
Doug Gaff is currently offline Doug GaffFriend
Try the eclipse.platform newsgroup for this question.
"Keanu, Paik" <yspaik@kr.ibm.com> wrote in message
news:80164a0e8769bd2d56a5cfbb330f762c$1@www.eclipse.org:
> I
> steps
> are
Re: Run and Debug j2me as "installed JREs" [message #569535 is a reply to message #7899] Mon, 08 May 2006 19:49 Go to previous message
> I
> steps
> are
Previous Topic:migrate some existing projects from Sun ONE Studio to Eclipse?
Next Topic:oh oh oh eclipse developer: bruta merda!
Current Time: Sun Dec 22 05:05:34 GMT 2024
Powered by FUDForum. Page generated in 0.03331 seconds
